    BME680 Temperature
    Highlighted
    BME680 Temperature
    I am using a BME680 sensor from MikroElektronika Environmental Click Board on an Azure Sphere MT3620.
    I implemented the BME680_driver.
    Unfortunately the temperature is about 5 degrees to high. But also it is not stable. It can vary from 25.5 and 25.7 in one minute.
    The pressure is working fine.
    Highlighted
    Re: BME680 Temperature
    I am not sure what are your test conditions, but 0.2°C variation in a non-controlled environment sounds reasonable. If you manage to integrate BSEC as well, you could make use of the BSEC_INPUT_HEATSOURCE feature to compensate for temperature influence from external factors.
    Highlighted
    I did not integrate BSEC. Is it possible to compensate with the BME680 driver?
    Highlighted
    Unfortunately this feature is built-in BSEC only but not available in the BME680 drivers.
