    BME680 always results in BME680_W_NO_NEW_DATA
    mayor
    Hi, I am integrating a BME680 with a TI CC1312 microcontroller. I can communicate fine with the sensor over I2C, from all appearances, but any time I am trying to take readings (even from the self-test from https://github.com/BoschSensortec/BME680_driver), I am getting no new data from the sensor. I have also tried a couple different units, getting the same results.
    Here's some calibration info:
    par_h1	unsigned short	717
    par_h2	unsigned short	1022
    par_h3	char	0 '\x00'
    par_h4	char	45 '-'
    par_h5	char	20 '\x14'
    par_h6	unsigned char	120 'x'
    par_h7	char	-100 '\x9c'
    par_gh1	char	-47 '\xd1'
    par_gh2	short	-11597
    par_gh3	char	18 '\x12'
    par_t1	unsigned short	26045
    par_t2	short	26419
    par_t3	char	3 '\x03'
    par_p1	unsigned short	36759
    par_p2	short	-10411
    par_p3	char	88 'X'
    par_p4	short	7301
    par_p5	short	-50
    par_p6	char	30 '\x1e'
    par_p7	char	51 '3'
    par_p8	short	-3768
    par_p9	short	-2137
    par_p10	unsigned char	30 '\x1e'
    t_fine	int	0
    res_heat_range	unsigned char	1 '\x01'
    res_heat_val	char	47 '/'
    range_sw_err	char	-1 '\xff'
     And this is what comes out from the sensor when trying to read data:
    [0]	unsigned char	0 '\x00'
    [1]	unsigned char	0 '\x00'
    [2]	unsigned char	128 '\x80'
    [3]	unsigned char	0 '\x00'
    [4]	unsigned char	0 '\x00'
    [5]	unsigned char	128 '\x80'
    [6]	unsigned char	0 '\x00'
    [7]	unsigned char	0 '\x00'
    [8]	unsigned char	128 '\x80'
    [9]	unsigned char	0 '\x00'
    [10]	unsigned char	128 '\x80'
    [11]	unsigned char	0 '\x00'
    [12]	unsigned char	0 '\x00'
    [13]	unsigned char	0 '\x00'
    [14]	unsigned char	4 '\x04'
    Any help appreciated!
    12 REPLIES 12
    Vincent
    Please share your code implementation here.
    From the register value you posted,  the measurement of sensor is not really happen,  all result is 0.
    mayor
    Hi Vincent,
    well, my code is essentially the self-test code from the Bosh GitHub.
    I have created read/write i2c functions as well as delay, which appear to be working (I can read and write to registers, see calibration registers).
    int8_t BME680::i2c_read(uint8_t reg_addr, uint8_t *reg_data, uint16_t len) {
        uint8_t writeBuf[1] = {reg_addr};
        i2cTransaction.readCount = len;
        i2cTransaction.readBuf = reg_data;
        i2cTransaction.writeCount = 1;
        i2cTransaction.writeBuf = writeBuf;
        bool status = I2C_transfer(i2c, &i2cTransaction);
        return !status;
    int8_t BME680::i2c_write(uint8_t reg_addr, uint8_t *reg_data, uint16_t len) {
        i2cTransaction.readCount  = 0;
        i2cTransaction.writeCount = len;
        i2cTransaction.writeBuf = reg_data;
        return !status;
    void BME680::delay(uint32_t delayMs) {
        Task_sleep(delayMs*100); //fixme, must take into account actual duration of a tick (10us here)
    Vincent
    Then in this case,  can you try to read out whole register map of BME680 and provide here?
    mayor
    here's what I see (same order as they appear in the docs):
    0xd0: 97
    0x72: 0
    0x74: 100
    0x75: 0
    0x50: 0
    0x51: 0
    0x52: 0
    0x53: 0
    0x54: 114
    0x55: 0
    0x56: 0
    0x57: 0
    0x58: 0
    0x59: 0
    0x5a: 0
    0x5b: 0
    0x5c: 0
    0x5d: 0
    0x5e: 0
    0x5f: 0
    0x60: 0
    0x61: 0
    0x62: 0
    0x63: 0
    0x64: 0
    0x65: 0
    0x66: 0
    0x67: 0
    0x68: 0
    0x69: 0
    0x6a: 0
    0x6b: 0
    0x6c: 0
    0x6d: 0
    0x70: 0
    0x71: 0
    0x1f: 128
    0x20: 0
    0x21: 0
    0x22: 128
    0x23: 0
    0x24: 0
    0x25: 128
    0x26: 0
    0x2a: 0
    0x2b: 4
    0x1d: 0
