12-13-2019 02:35 PM
We are testing BME680 in mobile application, where the sensor is heated and measured periodically (every 5 minutes). The heating is done to 400C. The heating and measurement time is 30s and this is repeated three times. We have noticed that the sensor starts to move towards saturation limit ( around 13007335). This means that after a while we are not able to perform the measurements. Is the heating time too much and does this cause degradation? Is heating-cooling cycle too much for the sensor?
01-20-2020 09:57 AM
I am returning to this as we have now more data on this issue.
We have been testing Bosch BME680 on normal office settings with following cycle:
1. Heat to 400 C for 1 second
2. Drop the temperature for 150 C for 30 seconds
We repeat this cycle continuously. It seems that BME680 will saturate after couple of days and lose its sensitivity totally. At first you get some changes in resistance when person stands close to the sensor but after a day or two the sensor will essentially break down.
Is the cause for this the continuous heating? There is no mentioning of this in the spec sheet. According to it we assumed that the sensor could withstand prolonged heating at least on low temperature (150C).
01-20-2020 10:19 AM
