    BME680 gas resistanc no output
    rex
    My code is exactly the same as the code here,https://github.com/BoschSensortec/BME680_driver#example-for-reading-all-sensor-data
    But there is a issue, printf (", G: %d ohms", data.gas_resistance); there is no output
    Other data output is normal。
    Reading sensor data
    Example for reading all sensor data
        while(1)
            user_delay_ms(meas_period); /* Delay till the measurement is ready */
            printf("T: %.2f degC, P: %.2f hPa, H %.2f %%rH ", data.temperature / 100.0f,
                data.pressure / 100.0f, data.humidity / 1000.0f );//normal
            /* Avoid using measurements from an unstable heating setup */
            if(data.status & BME680_GASM_VALID_MSK)
                printf(", G: %d ohms", data.gas_resistance);//no output
            printf("\r\n");
            /* Trigger the next measurement if you would like to read data out continuously */
            if (gas_sensor.power_mode == BME680_FORCED_MODE) {
    This is the data I read and write, I use i2c
    write to 0x76 ack data: 0x74
    read to 0x76 ack data: 0x8C
    write to 0x76 ack data: 0x74 0x8D
    write to 0x76 ack data: 0x1D
    read to 0x76 ack data: 0x80 0x00 0x51 0xF7 0x30 0x7B 0x0A 0x50 0x52 0xC5 0x80 0x00 0x00 0x3C 0xB6
    read to 0x76 ack data: 0x80 0x00 0x51 0xF7 0x30 0x7B 0x0A 0x40 0x52 0xC3 0x80 0x00 0x00 0x3B 0x36
    10 REPLIES 10
    rex
    Can you give me some suggestions, thanks!
    Hello rex,
    In github, there is configuration part as well.
    I would like to check your configuratoin part also.
    Could you upload your whole bme680 code?
    void bme680_task_process(void){
    twi_init_bme680(&twi_cfg_bme);
    struct bme680_dev gas_sensor;
    gas_sensor.dev_id = BME680_I2C_ADDR_PRIMARY;
    gas_sensor.read = bme680_com_read;
    gas_sensor.write = bme680_com_write;
    gas_sensor.delay_ms = user_delay_ms;
    /* amb_temp can be set to 25 prior to configuring the gas sensor
    * or by performing a few temperature readings without operating the gas sensor.
    gas_sensor.amb_temp = 25;
    int8_t rslt = BME680_OK;
    //Regarding compensation functions for temperature, pressure, humidity and gas we have two implementations.
    //- Integer version
    //- floating point version
    //By default, Integer version is used in the API
    NRF_LOG_INFO("%s,id:%x\r\n",__FUNCTION__,gas_sensor.chip_id);
    //Example for configuring the sensor in forced mode
    gas_sensor.gas_sett.heatr_temp = 320; /* degree Celsius */
    gas_sensor.gas_sett.heatr_dur = 150; /* milliseconds */
    /* Select the power mode */
    set_required_settings = BME680_OST_SEL | BME680_OSP_SEL | BME680_OSH_SEL | BME680_FILTER_SEL | BME680_GAS_SENSOR_SEL;
    rslt = bme680_set_sensor_settings(set_required_settings,&gas_sensor);
    /* Set the power mode */
    //reading all sensor data
    /* Get the total measurement duration so as to sleep or wait till the
    * measurement is complete */
    uint16_t meas_period;
    struct bme680_field_data data;
    char temperature[20];
    char pressure[20];
    char humidity[20];
    while(1)
    sprintf(temperature,"%f",data.temperature / 100.0f);
    NRF_LOG_INFO("%s,temperature:%s degC\r\n",__FUNCTION__,temperature); //normal
    sprintf(pressure,"%f",data.pressure / 100.0f);
    NRF_LOG_INFO("%s,pressure:%s hPa\r\n",__FUNCTION__,pressure); //normal
    sprintf(humidity,"%f",data.humidity / 1000.0f);
    NRF_LOG_INFO("%s,humidity:%s rH\r\n",__FUNCTION__,humidity); //normal
    //printf("T: %.2f degC, P: %.2f hPa, H %.2f %%rH ", data.temperature / 100.0f,
    //data.pressure / 100.0f, data.humidity / 1000.0f );
    if(data.status & BME680_GASM_VALID_MSK){
    NRF_LOG_INFO("%s,gas_resistance:%d ohms\r\n",__FUNCTION__,data.gas_resistance); ////no output
    //printf(", G: %d ohms", data.gas_resistance);//气体电阻(欧姆)
    //printf("\r\n");
    gas_sensor.power_mode=BME680_FORCED_MODE;
    Hi, minhwan
    this is after the last task is run, the logic analyzer gets the data, thank you
    write to 0x76 ack data: 0xE0 0xB6
    write to 0x76 ack data: 0xD0
    read to 0x76 ack data: 0x61
    write to 0x76 ack data: 0x89
    read to 0x76 ack data: 0x80 0x4D 0x67 0x03 0x30 0x24 0x8D 0x90 0xD7 0x58 0x00 0xE4 0x1E 0x6E 0xFF 0x1F 0x1E 0x00 0x00 0x09 0xFB 0xA8 0xF3 0x1E 0x7F
    write to 0x76 ack data: 0xE1
    read to 0x76 ack data: 0x3F 0xE7 0x2C 0x00 0x2D 0x14 0x78 0x9C 0xC2 0x66 0xBD 0xE6 0xDF 0x12 0x9D 0x00
    write to 0x76 ack data: 0x02
    read to 0x76 ack data: 0x16
    write to 0x76 ack data: 0x00
    read to 0x76 ack data: 0x2F
    write to 0x76 ack data: 0x04
    read to 0x76 ack data: 0x03
    write to 0x76 ack data: 0x5A 0x41 0x64 0x65
    read to 0x76 ack data: 0x00
    write to 0x76 ack data: 0x75
    write to 0x76 ack data: 0x72
    write to 0x76 ack data: 0x71
    write to 0x76 ack data: 0x75 0x08 0x74 0x8C 0x72 0x02 0x71 0x10
    read to 0x76 ack data: 0x80 0x00 0x50 0xD6 0x80 0x78 0x8A 0x80 0x56 0xEE 0x80 0x00 0x00 0x2D 0xF5
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x70 0x78 0x9F 0x00 0x57 0x01 0x80 0x00 0x00 0x66 0x35
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x50 0x78 0x9E 0x40 0x57 0x17 0x80 0x00 0x00 0x66 0xB5
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x00 0x78 0x9D 0xA0 0x57 0x18 0x80 0x00 0x00 0x66 0x35
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x20 0x78 0x9D 0x30 0x57 0x0A 0x80 0x00 0x00 0x66 0xB5
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x20 0x78 0x9D 0x00 0x56 0xF1 0x80 0x00 0x00 0x66 0x35
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x20 0x78 0x9C 0xC0 0x56 0xD4 0x80 0x00 0x00 0x64 0xF5
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x50 0x78 0x9C 0xC0 0x56 0xB8 0x80 0x00 0x00 0x65 0x75
