01-29-2021 11:47 AM
Hello I am trying to use the bme680 to get the iaq measurements with the BSEC library. It reads only the default values for the iaq sensor even though i load the state in the code as well as saving the state everytime the accuracy is greater than 3 but the accuracy never seems to get to more than 0 and the sensor reads the default values all the time this has been going for a whole week.
01-29-2021 06:02 PM
Hello AN_,
There are IAQ, and IAQ accuracy, IAQ shall be greater than 3, the initial value would be 25.
I can't see your screenshot, but if you get 25 at the beginning, you are fine.
01-31-2021 07:59 PM
Well yes i get 25 in the beginning, however, it stayed like this for a whole week. Is this a problem with the calibration?
02-01-2021 04:52 PM
Hello AN,
Could you share your source code if you don't mind?
