Can you please share some more details about your working solution?
I'm stuck with ESPhome and BSEC library as I don't get any other values than 25 from iaqSensor.iaq.
Thanks in advance,
Andreas
I am using the BME680 connected in I2C with ESP32 with ESPHOME and BSEC library installed.
But I have the same problems.
I can read temperature, humidity, pressure and gas resistance, but the IAQ is always 25 and the accuracy of the IAQ is 0.
Any suggestions ?
Thank
In case it helps anyone this is my setup which I've had running without issue for a while now on a couple of ESP8266 wemos d1 minis.
bsecsensor.h
#include <esphome.h>
#include <bsec.h>
#include <Wire.h>
#include <EEPROM.h>
const uint8_t bsec_config_iaq[] = {
#include "config/generic_33v_3s_28d/bsec_iaq.txt"
#define STATE_SAVE_PERIOD UINT32_C(360 * 60 * 1000) // 360 minutes - 4 times a day
static const char *TAG = "bsec";
class BSECSensor : public Component {
private:
Bsec iaqSensor;
bsec_library_return_t bsecStatus = BSEC_OK;
int8_t bme680Status = BME680_OK;
uint8_t bsecState[BSEC_MAX_STATE_BLOB_SIZE] = {0};
uint16_t stateUpdateCounter = 0;
uint8_t sensorPushNum = 0;
bool checkIaqSensorStatus(void) {
if (iaqSensor.status != BSEC_OK && iaqSensor.status != bsecStatus) {
if (iaqSensor.status < BSEC_OK) {
ESP_LOGE(TAG, "BSEC error code: %d", iaqSensor.status);
status_set_error();
} else {
ESP_LOGW(TAG, "BSEC warning code: %d", iaqSensor.status);
status_set_warning();
if (iaqSensor.bme680Status != BME680_OK && iaqSensor.bme680Status != bme680Status) {
if (iaqSensor.bme680Status < BME680_OK) {
ESP_LOGE(TAG, "BME680 error code: %d", iaqSensor.bme680Status);
status_set_error();
} else {
ESP_LOGW(TAG, "BME680 warning code: %d", iaqSensor.bme680Status);
bsecStatus = iaqSensor.status;
bme680Status = iaqSensor.bme680Status;
if (bsecStatus < BSEC_OK || bme680Status < BME680_OK) {
return false;
status_clear_error();
status_clear_warning();
return true;
void loadState(void) {
if (EEPROM.read(0) == BSEC_MAX_STATE_BLOB_SIZE) {
// Existing state in EEPROM
ESP_LOGI(TAG, "Reading state from EEPROM");
for (uint8_t i = 0; i < BSEC_MAX_STATE_BLOB_SIZE; i++) {
bsecState[i] = EEPROM.read(i + 1);
iaqSensor.setState(bsecState);
checkIaqSensorStatus();
// Don't immediately update after initial load
stateUpdateCounter++;
} else {
// Erase the EEPROM with zeroes
ESP_LOGI(TAG, "Erasing EEPROM");
for (uint8_t i = 0; i < BSEC_MAX_STATE_BLOB_SIZE + 1; i++) {
EEPROM.write(i, 0);
EEPROM.commit();
void updateState(void) {
if (
// First state update when IAQ accuracy is >= 3
(stateUpdateCounter == 0 && iaqSensor.staticIaqAccuracy >= 3)
// Then update every STATE_SAVE_PERIOD minutes
|| ((stateUpdateCounter * STATE_SAVE_PERIOD) < millis())
} else {
return;
iaqSensor.getState(bsecState);
if (!checkIaqSensorStatus()) {
return;
ESP_LOGI(TAG, "Writing state to EEPROM");
for (uint8_t i = 0; i < BSEC_MAX_STATE_BLOB_SIZE ; i++) {
EEPROM.write(i + 1, bsecState[i]);
EEPROM.write(0, BSEC_MAX_STATE_BLOB_SIZE);
EEPROM.commit();
public:
Sensor *temperature = new Sensor();
Sensor *humidity = new Sensor();
Sensor *pressure = new Sensor();
Sensor *gasResistance = new Sensor();
Sensor *staticIaq = new Sensor();
Sensor *staticIaqAccuracy = new Sensor();
Sensor *co2Equivalent = new Sensor();
Sensor *breathVocEquivalent = new Sensor();
void setup() override {
EEPROM.begin(BSEC_MAX_STATE_BLOB_SIZE + 1);
iaqSensor.begin(BME680_I2C_ADDR_PRIMARY, Wire);
ESP_LOGI(
TAG, "BSEC Version: %d.%d.%d.%d",
iaqSensor.version.major, iaqSensor.version.minor,
iaqSensor.version.major_bugfix, iaqSensor.version.minor_bugfix
iaqSensor.setConfig(bsec_config_iaq);
// Load state from EEPROM
loadState();
// Subscribe to sensor values
bsec_virtual_sensor_t sensorList[7] = {
BSEC_OUTPUT_RAW_PRESSURE,
BSEC_OUTPUT_RAW_GAS,
BSEC_OUTPUT_STATIC_IAQ,
BSEC_OUTPUT_CO2_EQUIVALENT,
iaqSensor.updateSubscription(sensorList, 7, BSEC_SAMPLE_RATE_LP);
void setTemperatureOffset(float temp) {
iaqSensor.setTemperatureOffset(temp);
void loop() override {
if (checkIaqSensorStatus() && iaqSensor.run()) {
sensorPushNum = 1;
updateState();
// In order not to block here, spread the sensor state pushes
// across subsequent calls otherwise we end up with API disconnects
if (sensorPushNum > 0 && sensorPushNum <= {
switch (sensorPushNum++) {
case 1: temperature->publish_state(iaqSensor.temperature); break;
case 2: humidity->publish_state(iaqSensor.humidity); break;
case 3: pressure->publish_state(iaqSensor.pressure); break;
case 4: gasResistance->publish_state(iaqSensor.gasResistance); break;
case 5: staticIaq->publish_state(iaqSensor.staticIaq); break;
case 6: staticIaqAccuracy->publish_state(iaqSensor.staticIaqAccuracy); break;
case 7: co2Equivalent->publish_state(iaqSensor.co2Equivalent); break;
case 8: breathVocEquivalent->publish_state(iaqSensor.breathVocEquivalent); break;
.bsecsensor.yaml
Note: I have to specifiy a specific patched arduino version due to the ESP8266 memory layout per the library readme. If you're going to use this please fork the Arduino repo and modify the platform_packages directive accordingly as I can't guarantuee what state my copy will be in long term. I imagine on an ESP32 it would "just work" with no need specify any arduino options.
esphome:
platform: ESP8266
board: d1_mini
includes:
- bsecsensor.h
libraries:
- 'BSEC Software Library'
arduino_version: '2.5.2'
platformio_options:
# Use patched arduino to modify BSEC library memory location
# https://github.com/BoschSensortec/BSEC-Arduino-library#4-additional-core-specific-modifications
platform_packages: framework-arduinoespressif8266 @ https://github.com/trvrnrth/Arduino.git
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
ap:
ssid: ${location} Climate Sensor
password: !secret ap_password
captive_portal:
logger:
level: INFO
esp8266_store_log_strings_in_flash: False
api:
ota:
status_led:
pin:
number: 2
inverted: True
i2c:
sda: 4
scl: 5
scan: False
sensor:
- platform: custom
lambda: |-
auto sensor = new BSECSensor();
sensor->setTemperatureOffset(${temp_offset});
App.register_component(sensor);
return {
sensor->temperature,
sensor->humidity,
sensor->pressure,
sensor->gasResistance,
sensor->staticIaq,
sensor->staticIaqAccuracy,
sensor->co2Equivalent,
sensor->breathVocEquivalent,
sensors:
- name: ${location} Temperature
unit_of_measurement: '°C'
accuracy_decimals: 1
icon: mdi:thermometer
filters:
- median
- name: ${location} Humidity
unit_of_measurement: '%'
icon: mdi:water-percent
filters:
- median
- name: ${location} Pressure
unit_of_measurement: 'hPa'
icon: mdi:gauge
filters:
- median
- name: ${location} Gas Resistance
unit_of_measurement: 'Ω'
icon: mdi:gas-cylinder
filters:
- median
- name: ${location} Static IAQ
unit_of_measurement: IAQ
icon: mdi:gauge
filters:
- median
- id: ${location_id}_raw_static_iaq_accuracy
internal: True
on_value:
- text_sensor.template.publish:
state: !lambda |-
if (x == 0) return "Stabilizing";
if (x == 1) return "Uncertain";
if (x == 2) return "Calibrating";
if (x == 3) return "Calibrated";
return "Invalid";
- name: ${location} CO2 Equivalent
unit_of_measurement: 'ppm'
icon: mdi:test-tube
filters:
- median
- name: ${location} Breath VOC Equivalent
icon: mdi:test-tube
filters:
- median
text_sensor:
- platform: template
name: ${location} Static IAQ Accuracy
icon: mdi:checkbox-marked-circle-outline
test_climate.yaml
substitutions:
location_id: test
temp_offset: '0'
<<: !include .bsecsensor.yaml
Thank you very much trvrnrth, function !!!! 😀
I got some errors, but I was able to continue.
There is an error in this line
I think there is a missing value after <=
Another mistake is here
here I get: Unable to find action with the name 'text_sensor.template.publish'.
But in any case I found a way to get it running.
So again thank you.
Good to hear it's working for you!
There seems to be some emoji detection or something mangling things. The line in error should read:
if (sensorPushNum > 0 && sensorPushNum <= 8 ) {
Weird that the text sensor publish isn't working for you as that's being used as detailed in the docs. You might want to double check your editor hasn't messed up the indentation there.
