    BME680 platform IO ESP32
    handytech
    Re: BME680 platform IO ESP32
    Please note that in your latest update you have changed the name of the library in the build_flags. You need to use "-lalgobsec" for the compiler to look for the file libalgobsec.a.
    peter3099
    Finally I got it to  compile, thanks so much for that
    In case anybody need it the final platform.ini file needs to have
    If you want to have the libraries install within the project folder
    build_flags =
      -I .pio/libdeps/esp32/BSEC\ Software\ Library_ID6979/src/inc
      -L .pio/libdeps/esp32/BSEC\ Software\ Library_ID6979/src/esp32
      -lalgobsec
    lib_deps =
        BSEC Software Library
    One can also install the library locally and point the path to the different folders
    Stay safe!
    Yashgulati0
    Hello Guy's,
    I am using STM32f103C8T6 module as a arduino framework but I am unble to complile the below mentioned BMSC library in Platform IO.
    boschsensortec/BSEC Software Library@^1.6.1480
    While complaing the basic.ino file the PIO is generating belwo mentioend error.
    c:/users/yusata infotech/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -lalgobsec
    *** [.pio\build\genericSTM32F103CB\firmware.elf] Error 1
    =========================================================== [FAILED] Took 41.81 seconds ===========================================================
    Can anyone let me know how to fix this error???
