    BME680 stopped working, shows humidity 0, gas 0
    the sensor BME680 stopped "working" after few hours when environment changed (opened window)
    Now it shows humidity 0 and says heating is not stable.
    Pressure and temperature is working.
    Used profile is heat 320, 150ms time. Read in loop each 1s. Vcc is 3.3V.
    So what should happened? And how to prevent it? Can be problem the fast change of temperature from window (from 25C to cca 15C) ?
    Jarek
    Tags (2)
    Re: BME680 stopped working, shows humidity 0, gas 0
    Can you provide the DataLog when the issue occurred? Please provide the Raw_humidity/Raw_temperature/Raw_pressure/Raw_Gas_Res timestamp ,the BSEC output and the error code from BSEC or API.
    Is this issue 100% reproducible or just random?
