    BME680 with BSEC produces on 0.0s, even after 20 min
    mhammer3
    Dear all,
    I have integrated the "BSEC_1.4.8.0_Generic_Release" into my application to operate the BME680 based on "BME680 shuttle board" over I2C (SD0 set to GROUND).
    The result is: the callback function of "output_ready" produces only 0.0s, even after 10 mins of operation:
    730703 DEBUG: T: 0.00 degC, P: 0.00 hPa, H 0.00 rH, G: 0.00 ohms
    733703 DEBUG: T: 0.00 degC, P: 0.00 hPa, H 0.00 rH, G: 0.00 ohms
    736703 DEBUG: T: 0.00 degC, P: 0.00 hPa, H 0.00 rH, G: 0.00 ohms
    739703 DEBUG: T: 0.00 degC, P: 0.00 hPa, H 0.00 rH, G: 0.00 ohms
    742703 DEBUG: T: 0.00 degC, P: 0.00 hPa, H 0.00 rH, G: 0.00 ohms
    The setup is:
    STM32L462RE
    toolchain: SysGcc, GCC 7.2.0, GDB 8.0.1 revision 3
    software: BSEC_1.4.8.0_Generic_Release
    integrated lib: BSEC_1.4.8.0_Generic_Release/algo/normal_version/bin/gcc/Cortex_M4F/libalgobsec.a
    integrated software samples (as is, unchanged!)
    BSEC_1.4.8.0_Generic_Release/examples/bsec_iot_example.c
    BSEC_1.4.8.0_Generic_Release/examples/bsec_iot_example/bme680.c
    BSEC_1.4.8.0_Generic_Release/examples/bsec_iot_example/bsec_integration.c
    callback functions I have populated:
    bus_read, bus_write, sleep (in ms), get_timestamp_us (in us), output_ready
    callback functions I have left empty:
    state_load, state_save.
    Any help to resolve this issue is much appreciated.
    6 REPLIES 6
    Re: BME680 with BSEC produces on 0.0s, even after 20 min
    Hello mhammer3,
    When you run BME680 example, could you get chip ID in bme680_init()?
    mhammer3
    the chip_id after calling bme680_init is 0x61.
    mhammer3
    Please note: I am running the "bsec_iot_example.c" example
    Hello ,
    After your code called bsec_iot_init(), all return values were correct in bsec_iot_init()?
