03-19-2019 08:11 PM - last edited on 03-20-2019 03:50 PM by handytech
Hello ,
I'm in your forum, because I have problems with your BME680.
I need datas temperature,humidity, pressure, IAQ and voc/co2.
The mainly problem are the data VOC and CO2. The datas are always zero.
I use mainly your example bsec code plus WLAN and MQTT code for my esp8266.
I use the BSEC lib v1.4.7.2
can you help me?
/*! * @file bsec_iot_example.ino * * @brief * Example for using of BSEC library in a fixed configuration with the BME680 sensor. * This works by running an endless loop in the bsec_iot_loop() function. */ /*! * @addtogroup bsec_examples BSEC Examples * @brief BSEC usage examples * @{*/ /**********************************************************************************************************************/ /* header files */ /**********************************************************************************************************************/ #include <ESP8266WiFi.h> #include <PubSubClient.h> #include <Wire.h> #include <SPI.h> #include "bsec_integration.h" #include <Wire.h> const char* SSID = "*SSID NAME*"; const char* PSK = "*PASSWORD*"; const char* MQTT_BROKER = "192.168.178.41"; WiFiClient espClient; PubSubClient client(espClient); long lastMsg = 0; char msg[50]; int value = 0; // Hilfsvariablen für die Convertierung der Temperatur in ein String char tempBuffer[100]; /**********************************************************************************************************************/ /* functions */ /**********************************************************************************************************************/ /*! * @brief Write operation in either Wire or SPI * * param[in] dev_addr Wire or SPI device address * param[in] reg_addr register address * param[in] reg_data_ptr pointer to the data to be written * param[in] data_len number of bytes to be written * * @return result of the bus communication function */ int8_t bus_write(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data_ptr, uint16_t data_len) { Wire.beginTransmission(dev_addr); Wire.write(reg_addr); /* Set register address to start writing to */ /* Write the data */ for (int index = 0; index < data_len; index++) { Wire.write(reg_data_ptr[index]); } return (int8_t)Wire.endTransmission(); } /*! * @brief Read operation in either Wire or SPI * * param[in] dev_addr Wire or SPI device address * param[in] reg_addr register address * param[out] reg_data_ptr pointer to the memory to be used to store the read data * param[in] data_len number of bytes to be read * * @return result of the bus communication function */ int8_t bus_read(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data_ptr, uint16_t data_len) { int8_t comResult = 0; Wire.beginTransmission(dev_addr); Wire.write(reg_addr); /* Set register address to start reading from */ comResult = Wire.endTransmission(); delayMicroseconds(150); /* Precautionary response delay */ Wire.requestFrom(dev_addr, (uint8_t)data_len); /* Request data */ int index = 0; while (Wire.available()) /* The slave device may send less than requested (burst read) */ { reg_data_ptr[index] = Wire.read(); index++; } return comResult; } /*! * @brief System specific implementation of sleep function * * @param[in] t_ms time in milliseconds * * @return none */ void sleep(uint32_t t_ms) { delay(t_ms); } /*! * @brief Capture the system time in microseconds * * @return system_current_time current system timestamp in microseconds */ int64_t get_timestamp_us() { return (int64_t) millis() * 1000; } /*! * @brief Handling of the ready outputs * * @param[in] timestamp time in nanoseconds * @param[in] iaq IAQ signal * @param[in] iaq_accuracy accuracy of IAQ signal * @param[in] temperature temperature signal * @param[in] humidity humidity signal * @param[in] pressure pressure signal * @param[in] raw_temperature raw temperature signal * @param[in] raw_humidity raw humidity signal * @param[in] gas raw gas sensor signal * @param[in] bsec_status value returned by the bsec_do_steps() call * * @return none */ void output_ready(int64_t timestamp, float iaq, uint8_t iaq_accuracy, float temperature, float humidity, float pressure, float raw_temperature, float raw_humidity, float gas, bsec_library_return_t bsec_status, float static_iaq, float co2_equivalent, float breath_voc_equivalent) { if (!client.connected()) { reconnect(); } client.loop(); snprintf (msg, 50, "In Betrieb seit %ld milliseconds", millis()); Serial.print("["); Serial.print(timestamp/1e6); Serial.print("] T: "); Serial.print(temperature); client.publish("/home/Temperatur", dtostrf(temperature, 1, 2, tempBuffer)); // in Grad Serial.print("| rH: "); Serial.print(humidity); client.publish("/home/Feuchtigkeit", dtostrf(humidity, 1, 2, tempBuffer)); // in % Serial.print("| IAQ: "); Serial.print(iaq); client.publish("/home/IAQ", dtostrf(iaq, 1, 2, tempBuffer)); Serial.print(" ("); Serial.print(iaq_accuracy); Serial.print("| Static IAQ: "); Serial.print(static_iaq); Serial.print("| CO2e: "); Serial.print(co2_equivalent); client.publish("/home/CO2", dtostrf(co2_equivalent, 1, 2, tempBuffer)); Serial.print("| bVOC: "); Serial.println(breath_voc_equivalent); client.publish("/home/VOC", dtostrf(breath_voc_equivalent, 1, 2, tempBuffer)); client.publish("/home/Luftdruck", dtostrf(pressure/100.0, 1, 2, tempBuffer)); } /*! * @brief Load previous library state from non-volatile memory * * @param[in,out] state_buffer buffer to hold the loaded state string * @param[in] n_buffer size of the allocated state buffer * * @return number of bytes copied to state_buffer */ uint32_t state_load(uint8_t *state_buffer, uint32_t n_buffer) { // ... // Load a previous library state from non-volatile memory, if available. // // Return zero if loading was unsuccessful or no state was available, // otherwise return length of loaded state string. // ... return 0; } /*! * @brief Save library state to non-volatile memory * * @param[in] state_buffer buffer holding the state to be stored * @param[in] length length of the state string to be stored * * @return none */ void state_save(const uint8_t *state_buffer, uint32_t length) { // ... // Save the string some form of non-volatile memory, if possible. // ... } /*! * @brief Load library config from non-volatile memory * * @param[in,out] config_buffer buffer to hold the loaded state string * @param[in] n_buffer size of the allocated state buffer * * @return number of bytes copied to config_buffer */ uint32_t config_load(uint8_t *config_buffer, uint32_t n_buffer) { // ... // Load a library config from non-volatile memory, if available. // // Return zero if loading was unsuccessful or no config was available, // otherwise return length of loaded config string. // ... return 0; } /*! * @brief Main function which configures BSEC library and then reads and processes the data from sensor based * on timer ticks * * @return result of the processing */ void setup() { return_values_init ret; /* Init I2C and serial and WLAN/MQTT communication */ Wire.begin(); Serial.begin(115200); setup_wifi(); client.setServer(MQTT_BROKER, 1883); /* Call to the function which initializes the BSEC library * Switch on low-power mode and provide no temperature offset */ ret = bsec_iot_init(BSEC_SAMPLE_RATE_LP, 5.0f, bus_write, bus_read, sleep, state_load, config_load); if (ret.bme680_status) { /* Could not intialize BME680 */ Serial.println("Error while initializing BME680"); return; } else if (ret.bsec_status) { /* Could not intialize BSEC library */ Serial.println("Error while initializing BSEC library"); return; } /* Call to endless loop function which reads and processes data based on sensor settings */ /* State is saved every 10.000 samples, which means every 10.000 * 3 secs = 500 minutes */ bsec_iot_loop(sleep, get_timestamp_us, output_ready, state_save, 10000); } void setup_wifi() { delay(10); Serial.println(); Serial.print("Connecting to "); Serial.println(SSID); WiFi.begin(SSID, PSK); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println(""); Serial.println("WiFi connected"); Serial.println("IP address: "); Serial.println(WiFi.localIP()); } void reconnect() { while (!client.connected()) { Serial.print("Reconnecting..."); if (!client.connect("ESP8266Client")) { Serial.print("failed, rc="); Serial.print(client.state()); Serial.println(" retrying in 5 seconds"); delay(5000); } } // Initialisierung von Oversampling und Filter bme.setTemperatureOversampling(BME680_OS_8X); bme.setHumidityOversampling(BME680_OS_2X); bme.setPressureOversampling(BME680_OS_4X); bme.setIIRFilterSize(BME680_FILTER_SIZE_3); bme.setGasHeater(320, 150); // 320*C for 150 ms } void loop() { } /*! @}*/
03-20-2019 03:48 PM
Based on your code snippet, it seems that you are using our bsec_integration.c sample code. As you have found in this other thread, you will need to subscribe to the specific virtual outputs you would like to enable. In bsec_integration.c, this is done in the fuction bme680_bsec_update_subscription(). To enable the eCO2 and bVOC outputs, please make sure BSEC_OUTPUT_CO2_EQUIVALENT and BSEC_OUTPUT_BREATH_VOC_EQUIVALENT are correctly fed into bsec_update_subscription().
A few comments after a brief overlook at your code snippet:
03-20-2019 09:09 PM - edited 03-20-2019 09:17 PM
what do you mean with "...overwritten in reconnect() ?
I don't overwrite configurations.
And I deleted my 5s delay.
03-22-2019 12:01 PM
In the example file bsec_integration.c , the function bme680_bsec_trigger_measurement() already handles the configuration of the different sensor settings, then triggers a measurement. Therefore it wasn't clear whether this extra piece of code could interfere with BSEC's operation.
