Hello
I have acquired several development kits containing eight BME688 sensors.
I did several experiments, collected data with the kits at the same time with identical conditions then exported to BME AI-Studio and trained the data.
Training results seem pretty good and consistent but different from kit to kit.
I swapped only the sensor data from the kits that I have done in clean air and trained again and yes they are still different from each other.
I did 24 burn in process in clean air for all sensor kits at the same time.
Do the sensors have different characteristics or tolerances that could be causing this issue or any other cause?
Hello Mankurt,
Thanks for your question.
There is deviation for each sensor. Therefore, the characteristic value for each sensor could be different.
For example, we mention sensor to sensor deviation could be +- 15%. (Check Table 3.)
https://www.bosch-sensortec.com/media/boschsensortec/downloads/datasheets/bst-bme688-ds000.pdf
To get more accurate AI config file for all sensors, please gather data as many as sensors you have, then train it.
Then, you can get more general trend of specific gas or some chemical thing, then you can get it more accurately.
Please let me know if you have any quesitons.
