    BME688 - Arduino MKR WiFi 1010 Communication failure I2C
    Christoforos
    I am trying to get raw data from the BME688 sensor on a Sparkfun board on the Arduino MRK WiFi 1010 board using Arduino IDE 2.0.3 and I2C protocol. I have installed both BME68x and BSEC2 from GitHub. I am not sure if I actually need BSEC2 if I only neet raw data and not iaq.
    I can compile and upload the parallel_mode, sequential_mode and forced_mode examples and I get the same error in the Serial monitor:
    Sensor error:Communication failure
     I guess that the error comes from the code below:
    #ifndef PIN_CS
    #define PIN_CS SS
    #endif
    /* initializes the sensor based on SPI library */
    bme.begin(PIN_CS, Wire);
    I modified the line:  " bme.begin(PIN_CS, SPI); " to " bme.begin(PIN_CS, Wire); " such that I2C protocol is used instead of SPI.
    Any help please?
    Many thanks!
    6 REPLIES 6
    I believe you are using Arduino since your boards for Arduino.
    If so, you have to download BME68x API and BSEC2 for Arudino in below URL.
    You should add those 2 zip files in your Arduino library.
    Then, open BSEC2 example like basic.ino
    \Arduino\libraries\Bosch-BSEC2-Library-master\examples\generic_examples\basic\basic.ino
    You shouldn't touch BME68x API part.
    The default interface for BSEC2 is i2c, so you can directly use it.
    Dear  Minhwan,
    Thank you for your reply!
    Yes, I use Arduino IDE 2.0.3.
    I followed the steps you described exactly. When I compile for MKR Wifi 1010 I get the following warning:
    In file included from /Users/christoforospanteli/Documents/Arduino/libraries/Bosch-BSEC2-Library-master/src/bsec2.cpp:39:0:
    /Users/christoforospanteli/Documents/Arduino/libraries/Bosch-BSEC2-Library-master/src/bsec2.h: In member function 'const bsecData Bsec2::getData(bsecSensor)':
    /Users/christoforospanteli/Documents/Arduino/libraries/Bosch-BSEC2-Library-master/src/bsec2.h:154:13: warning: missing initializer for member 'bsec_output_t::signal' [-Wmissing-field-initializers]
    { 0 };
    /Users/christoforospanteli/Documents/Arduino/libraries/Bosch-BSEC2-Library-master/src/bsec2.h:154:13: warning: missing initializer for member 'bsec_output_t::signal_dimensions' [-Wmissing-field-initializers]
    /Users/christoforospanteli/Documents/Arduino/libraries/Bosch-BSEC2-Library-master/src/bsec2.h:154:13: warning: missing initializer for member 'bsec_output_t::sensor_id' [-Wmissing-field-initializers]
    /Users/christoforospanteli/Documents/Arduino/libraries/Bosch-BSEC2-Library-master/src/bsec2.h:154:13: warning: missing initializer for member 'bsec_output_t::accuracy' [-Wmissing-field-initializers]
    When I compile for esp32 I get the following error:
    /Users/christoforospanteli/Documents/Arduino/libraries/Bosch-BSEC2-Library-master/src/bsec2.cpp:138: undefined reference to `bsec_sensor_control'
    This means BSEC2 library works for MKR WiFi 1010 and I do get readings, but not for esp32. The parallel_mode example in the BME68x library compiles and uploads on both boards but I get "
    in the serial monitor. I want to save the raw data on an SD card, so my question is: Do I actually need BSEC or just BME68x library?
    Many thanks!
    I attach a document showing the circuit I am using.
    Did you check that you need pull up resistor for I2C or not?
    If you need, please put it.
