    BME688 BSEC bsec_sensor_control call delay
    Zaki13
    hello
    is there a mean to reduce the delay between 2 bsec_sensor_control calls.
    in my case the delay is almost acceptable for about 50 seconds ( 27ms between each call of bsec_sensor_control) , after that the delay for the next call will be 1min50s.
    regards.
    Zakaria
    2 REPLIES 2
    Minhwan
    Re: BME688 BSEC bsec_sensor_control call delay
    Are you using BSEC 2 right?
    If you are developing based on BSEC 1, I'd like to recommend to use BSEC 2.
    https://github.com/BoschSensortec/Bosch-BSEC2-Library
    And, bsec_sensor_control is controlled by power mode. You can't control manually.
    If you are using BSEC_SAMPLE_RATE_LP mode, it will be called every 3s. In case of BSEC_SAMPLE_RATE_ULP, it will be 300s.
    If you want to call more frequently, there is high performance mode. BSEC_SAMPLE_RATE_HIGH_PERFORMANCE
    Zaki13
    hello
    thanks for the message.
    i am using BSEC_2.0.6.1_Generic_Release_04302021.
    i will try the version you proposed.
    Regards.
    Zakaria
