08-02-2022 08:41 AM
Hello all,
I have done the coffee example with the DEV Kit x8. I imported the data into AI-Studio and then exported the BSEC file.
I have also prepared the Arduino lib.
In which file does the BSEC file go?
I want my ESP8266 to display Kaffe or normal air in the serial monitor.
Many greetings Tom!
08-02-2022 10:46 AM
Hi Tomi05,
If you would like to export BSEC config file and deploy it to Arduino platform. You could select a folder to export config file, then you will see the saved config file like this.
*.h and *.c files were used for Arduino platform.
08-02-2022 11:45 AM
08-03-2022 05:16 AM
Hi Tomi05,
When you export BSEC config file, the directory is selected by yourself.
08-03-2022 07:37 AM
