    BME688 BSEC update problem
    Zaki13
    hello
    i have developed a custom board using ATSAMD21G18A as MCU  and connected to a BME688 sensor.
    i used the BSEC example provided by bosh for arduino and modified it to meet our MCU ( changes in SPI functions and delay ).
    the problem is that when starting the application the bsecCallback function is called only once and after that no call is performed.
    i used the cortexM0+ as library.
    is there any modification to do to the Arduino example to avoid this problem ?
    thanks.
    Zakaria
    Hello Zaki13,
    Did you refer and run BSEC Arduino example on github?
    https://github.com/BoschSensortec/BSEC-Arduino-library/tree/master/examples
    hello
    thanks for your message.
    i fixed the problem, it was related to SPI timming.
    now the BSEC callback is called during 53 seconds and then stops updating for about 1min40s , and starts again for 53 seconds.
    is there any explation on this behaviour.
    Regards.
    zakaria
    by the way, iam using BSEC_2.0.6.1_Generic_Release_04302021.
    regards
    Zakaria
    Hi again
    du to availlability of Microcontrollers this days, i want to use this one  : PIC32MM0128GPM036.
    is this component compatible with one of the BSEC libraries provided.
    Regards.
    Zakaria
