    BME688 BSEC update problem
    Zaki13
    hello
    i have developed a custom board using ATSAMD21G18A as MCU  and connected to a BME688 sensor.
    i used the BSEC example provided by bosh for arduino and modified it to meet our MCU ( changes in SPI functions and delay ).
    the problem is that when starting the application the bsecCallback function is called only once and after that no call is performed.
    i used the cortexM0+ as library.
    is there any modification to do to the Arduino example to avoid this problem ?
    thanks.
    Zakaria
    Hello Zaki13,
    When the stop and start problem occurs, you need to check the behavior of the host. BSEC is only the called interface.
    PIC32MM0128GPM036 was not in BSEC supported list, if you design a project and need to support BSEC library on this host platform, you could visit https://www.bosch-sensortec.com/about-us/contact/contact-form, use the contact form to submit your request and please make sure you refer to the question posed in the community.
