07-22-2022 04:21 PM
Hello everyone,
Currently, I am working with the sensor BME 688 with the board Nucleo-WL55JC1.
I am reading and testing the code with the self-test (https://github.com/BoschSensortec/BME68x-Sensor-API/blob/master/examples/self_test/self_test.c) and the code did not work. I tracked the code and in the file bme68x.c line 156, the chip id was not equal to the constant BME68X_CHIP_ID which led to the error Device Not Found.
I have 2 assumptions:
I changed the code of I2C read and write based on the attached folder of this reference (In the comment) . Basically, I used the
09-07-2022 06:12 PM
Hello Robin,
My apologies for replying you this late.
It turns out that the way I implement was correct but somehow the tool (Visual Code) I used had some issue which I had no idea. Later I changed to STM32Cube IDE and it worked great without any issue.
Thank you very much for your response, Huy Nguyen.
09-09-2022 09:20 AM
Hi huytyskland,
It is good as it could work normally.
