    BME688 Data found for 1 heater profile / duty cycle combination
    Adrián
    Hello. When importing files to BME AI-Studio, the "data overview" section always shows the text "Data found for 1 heater profile / duty cycle combination", even if i'm using several temperature profiles.
    When training an algorithm I get results for each HP/RDC combination, but when testing it with the "BME688 demo" mobile app, it only uses one temperature profile for the 8 sensors on each board.
    The SD card of each board has the configuration and algorithm files when using the app.
    Could it be due to a board error or am I doing something wrong?
    Regards, Adrian
    7 REPLIES 7
    Hi Adrián,
    Did you use BME688 dev kit and default binary programe to record data?
    Adrián
    Yes, I use the development kit and the apps downloaded from the official Bosch website.
    Hi Adrián,
    When you used BME688 dev kit to record data, dev kit will generate *.bmerawdata file, then you could import it to BME AI-Studio.
    Adrián
    I know, thanks. I have used the data files generated by 8 plates to train several algorithms. My question is: Why if my algorithms are created with the HP/RDC combinations configured on the boards but the "BME-AI studio" software only identifies 1 HP/RDC combination and the mobile app only uses 1 HP/RDC combination in each board even if it should use more.
