01-26-2023 10:37 AM
Hello. When importing files to BME AI-Studio, the "data overview" section always shows the text "Data found for 1 heater profile / duty cycle combination", even if i'm using several temperature profiles.
When training an algorithm I get results for each HP/RDC combination, but when testing it with the "BME688 demo" mobile app, it only uses one temperature profile for the 8 sensors on each board.
The SD card of each board has the configuration and algorithm files when using the app.
Could it be due to a board error or am I doing something wrong?
Regards, Adrian
02-01-2023 07:43 AM
Hi Adrián,
BME688 dev kit uses eight sensors to record data quickly. After the configuration file is generated, one sensor is used on the target board.
02-01-2023 02:27 PM
In that case, if different temperature profiles have been used, which one will work on the board when testing the algorithm?
Or can a different algorithm be exported for each HP/RDC combination?
02-06-2023 11:34 AM
I will continue testing. For now, I'll use a single HP/RDC combination on the board.
