05-17-2022 12:39 PM
I have integrated BME688 sensor with my microcontroller. I have followed all the steps provided in the API code. Whenever I start reading the data I am able to read the Temperature, Pressure, Humidity values but the gas adc reading always comes as zero. I also tried to check the validity of the gas but it is also reading as zero.
Could you please help me in resolving this. Where can I go possibly wrong.
-Regards
05-18-2022 06:14 PM - edited 05-18-2022 06:17 PM
Hi hrishnspl,
You could refer attached BME688 example code which used sensor API on github: https://github.com/BoschSensortec/BME68x-Sensor-API
And check if you migrate example correctly.
05-23-2022 06:50 AM
As mentioned already, we have integrated the same code as mentioned in the github. But the gas resistance is zero. The settings used is same as the one mentioned in the code. We are able to read the temperature, humidity, pressure values correctly.
Also how should we confirm that the MOx sensor is reaching the set target temperature?
- Regards
06-14-2022 04:43 AM
Hi hrishnspl,
Can you compare your code with the reference code? The same code cannot get different results.
