unfortunately I also encounter the same problem. I also used the latest versions like @blblblu but I get the same error message in the smartphone app "Could not start sensor. response code: BSEC_CONFIG_MISSING"
Lisa
Did you create bmeconfig file from AI studio and copy into SD card?
I saw the error when I didn't copy the file into SD card.
Hello Minhwan,
yes. I tried it both with a completely new created bmeconfig from the AI-Studio, and with the one that is supplied as part of the board firmware (BME688_x8Board_v1.5.0), both result in the error message. It also doesn't matter if there is a bsec config created from an algorithm inside the AI studio.
Is there a specific file path for the configs? Currently, I just moved them as-is into the root directory of the SD card.
Sebastian
No, once you created your own bmeconfig file, just need to copy into SD card, not making folder.
It seems like another user faced similar issue, and fixed.
Could you check this one?
Minhwan,
none of the recomendations here are working... The one you sent, this doesnt apply as we clearly have the data logging (i.e SD card present). multiple people have the same issue..
