03-29-2022 02:02 PM - edited 03-29-2022 02:13 PM
Hello everyone,
I have a little problem with my new bme688 sensor. Sort breaf: I need to use it for temperature, humidity and pressure, to monitor a grow room. I took this sensor in hope to replace my currentDHT22( as I need pressure measurement as well, DHT22 have only temp and hum). My problem starts after some time, over 30 min, around a couple hours, of good readings my sensor suddenly give 195C and 100% humidity and seems to never come back to normal readings again. I'm using "sSense_BME680.h" library( - https://itbrainpower.net/downloadables/ssense_BME680_example.ino, from here) and arduino Due. It seems I can't make BSEC or BSEC2, it won't compile on my Due even if I do the steps from github( - https://github.com/BoschSensortec/Bosch-BSEC2-Library, this one).
i2c breakout that I'm using - https://itbrainpower.net/sensors/BME688
03-30-2022 10:07 AM
Hi Radu,
We haven't tested third-party software. The reference example is this one on GitHub: https://github.com/BoschSensortec/Bosch-BSEC2-Library. It is recommended to migrate the reference code to your platform and run.
03-30-2022 10:15 AM
I have encountered a similar problem recently, and I am trying to solve it
03-30-2022 12:21 PM
If only that code will work.
Running the basic example is giving me this error: Library BSEC_Software_Library has been declared precompiled:
Using precompiled library in C:\Users\d_rad\Documents\Arduino\libraries\BSEC_Software_Library\src\cortex-m3
The platform does not support 'compiler.libraries.ldflags' for precompiled libraries. I've dont required steps shown here - https://github.com/BoschSensortec/BSEC-Arduino-library. With or without editing 'platform.txt', the result is the same. That's why I've used that third-party lib and code...that did work but not for long.
04-13-2022 08:42 AM
Hi Radu, SterlingMinsha,
As you used BME688, you need to use BSEC2 project. Download software from:
or
First, refer the readme file: https://github.com/BoschSensortec/Bosch-BSEC2-Library/blob/master/README.md
On my ESP8266 platform, I had the following mofication:
Copy esp8266 version libalgobsec.a lib into SDK lib folder.
