    BME688 no new data found
    Rosso9
    HI,
    I'm using BME688 breakout board sensor with nRF52832 microcontroller. They communicate through I2C protocol.
    For the moment, I do not want ot use the BSEC library, I want to read the datas of Temperature, Pressure and Humidity and gas.
    I downloaded the API from github and I modified the common.c file to adapt to my microcontroller in this way
    #include <stdint.h>
    #include <stdlib.h>
    #include <stdio.h>
    #include <string.h>
    #include "bme68x.h"
    #include "bme68x_defs.h"
    #include "common.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    /*!                 Macro definitions                                         */
    /*! BME68X shuttle board ID */
    #define BME68X_SHUTTLE_ID  0x93
    #define SDA_PIN 18
    #define SCL_PIN 19
    /*!                Static variable definition                                 */
    static uint8_t dev_addr;
    static const nrf_drv_twi_t i2c_instance = NRF_DRV_TWI_INSTANCE(0);
    /*!                User interface functions                                   */
     * I2C read function map to COINES platform
    BME68X_INTF_RET_TYPE bme68x_i2c_read(uint8_t reg_addr, uint8_t *reg_data, uint32_t len, void *intf_ptr)
        uint8_t dev_addr = *(uint8_t*)intf_ptr;
        ret_code_t ret_code;
        ret_code = nrf_drv_twi_tx(&i2c_instance, dev_addr, &reg_addr,1,false);
        if(ret_code != NRF_SUCCESS)
            return ret_code;
        ret_code = nrf_drv_twi_rx(&i2c_instance, dev_addr, reg_data, len);
        if (ret_code == NRF_SUCCESS)
            return BME68X_OK;
        else
            return 1;
     * I2C write function map to COINES platform
    BME68X_INTF_RET_TYPE bme68x_i2c_write(uint8_t reg_addr, const uint8_t *reg_data, uint32_t len, void *intf_ptr)
        uint8_t send_tmp[10] = {0};
        send_tmp[0] = reg_addr;
        memcpy(send_tmp+1, reg_data, len);
        ret_code_t err_code = nrf_drv_twi_tx(&i2c_instance, dev_addr, send_tmp, len, false);
        if (ret_code == NRF_SUCCESS) return BME68X_OK;
        else return 1;
     * Delay function map to COINES platform
    void bme68x_delay_us(uint32_t period, void *intf_ptr)
        nrf_delay_us(period);
    int8_t bme68x_interface_init(struct bme68x_dev *bme, uint8_t intf)
        int8_t rslt = BME68X_OK;
        uint8_t reg_addr;
        const uint8_t *reg_data;
        uint32_t len;
        void *intf_ptr;
        if (bme != NULL)
            /* Bus configuration : I2C */
            if (intf == BME68X_I2C_INTF)
                dev_addr = BME68X_I2C_ADDR_LOW;
                bme->read = bme68x_i2c_read;
                bme->write = bme68x_i2c_write;
                bme->intf = BME68X_I2C_INTF;
                //coines_config_i2c_bus(COINES_I2C_BUS_0, COINES_I2C_STANDARD_MODE);
               /* const nrf_drv_twi_config_t i2c_instance_config = {  .scl = SCL_PIN,
        .sda = SDA_PIN,
        .frequency = NRF_TWI_FREQ_100K,
        .interrupt_priority = 0};
                rslt = nrf_drv_twi_init(&i2c_instance, &i2c_instance_config, NULL, NULL);
                //enable TWI instance
                nrf_drv_twi_enable(&i2c_instance);
            //coines_set_shuttleboard_vdd_vddio_config(3300, 3300);
            nrf_delay_ms(100);
            bme->delay_us = bme68x_delay_us;
            bme->intf_ptr = &dev_addr;
            bme->amb_temp = 25; /* The ambient temperature in deg C is used for defining the heater temperature */
        else
            rslt = BME68X_E_NULL_PTR;
        return rslt;
    void bme68x_check_rslt(const char api_name[], int8_t rslt)
        switch (rslt)
            case BME68X_OK:
                printf("API name [%s]: Tutto ok\n", api_name);
                /* Do nothing */
                break;
            case BME68X_E_NULL_PTR:
                printf("API name [%s]  Error [%d] : Null pointer\r\n", api_name, rslt);
                break;
            case BME68X_E_COM_FAIL:
                printf("API name [%s]  Error [%d] : Communication failure\r\n", api_name, rslt);
                break;
            case BME68X_E_INVALID_LENGTH:
                printf("API name [%s]  Error [%d] : Incorrect length parameter\r\n", api_name, rslt);
                break;
            case BME68X_E_DEV_NOT_FOUND:
                printf("API name [%s]  Error [%d] : Device not found\r\n", api_name, rslt);
                break;
            case BME68X_E_SELF_TEST:
                printf("API name [%s]  Error [%d] : Self test error\r\n", api_name, rslt);
                break;
            case BME68X_W_NO_NEW_DATA:
                printf("API name [%s]  Warning [%d] : No new data found\r\n", api_name, rslt);
                break;
            default:
                printf("API name [%s]  Error [%d] : Unknown error code\r\n", api_name, rslt);
                break;
    void bme68x_coines_deinit(void)
        fflush(stdout);
        coines_set_shuttleboard_vdd_vddio_config(0, 0);
        coines_delay_msec(1000);
        // Coines interface reset
        coines_soft_reset();
        coines_close_comm_intf(COINES_COMM_INTF_USB);
    Then, I try the example of forced mode
    struct bme68x_dev bme;
        int8_t rslt;
        struct bme68x_conf conf;
        struct bme68x_heatr_conf heatr_conf;
        struct bme68x_data data;
        uint32_t del_period;
        uint32_t time_ms = 0;
        uint8_t n_fields;
        uint16_t sample_count = 1;
        /* Interface preference is updated as a parameter
         * For I2C : BME68X_I2C_INTF
         * For SPI : BME68X_SPI_INTF
        rslt = bme68x_interface_init(&bme, BME68X_I2C_INTF);
        bme68x_check_rslt("bme68x_interface_init", rslt);
        rslt = bme68x_init(&bme);
        bme68x_check_rslt("bme68x_init", rslt);
        /* Check if rslt == BME68X_OK, report or handle if otherwise */
        conf.filter = BME68X_FILTER_OFF;
        conf.odr = BME68X_ODR_NONE;
        conf.os_hum = BME68X_OS_16X;
        conf.os_pres = BME68X_OS_1X;
        conf.os_temp = BME68X_OS_2X;
        rslt = bme68x_set_conf(&conf, &bme);
        bme68x_check_rslt("bme68x_set_conf", rslt);
        heatr_conf.enable = BME68X_ENABLE;
        heatr_conf.heatr_temp = 300;
        heatr_conf.heatr_dur = 100;
        rslt = bme68x_set_heatr_conf(BME68X_FORCED_MODE, &heatr_conf, &bme);
        bme68x_check_rslt("bme68x_set_heatr_conf", rslt);
        printf("Sample, TimeStamp(ms), Temperature(deg C), Pressure(Pa), Humidity(%%), Gas resistance(ohm), Status\n");
        while (sample_count <= SAMPLE_COUNT)
            rslt = bme68x_set_op_mode(BME68X_FORCED_MODE, &bme);
            bme68x_check_rslt("bme68x_set_op_mode", rslt);
            /* Calculate delay period in microseconds */
            del_period = bme68x_get_meas_dur(BME68X_FORCED_MODE, &conf, &bme) + (heatr_conf.heatr_dur * 1000);
            bme.delay_us(del_period, bme.intf_ptr);
            time_ms = count*50;
            rslt = bme68x_get_data(BME68X_FORCED_MODE, &data, &n_fields, &bme);
            bme68x_check_rslt("bme68x_get_data", rslt);
            if (n_fields)
    #ifdef BME68X_USE_FPU
                printf("%u, %lu, %.2f, %.2f, %.2f, %.2f, 0x%x\n",
                       sample_count,
                       (long unsigned int)time_ms,
                       data.temperature,
                       data.pressure,
                       data.humidity,
                       data.gas_resistance,
                       data.status);
    #else
                printf("%u, %lu, %d, %lu, %lu, %lu, 0x%x\n",
                       sample_count,
                       (data.temperature / 100),
                       (long unsigned int)data.pressure,
                       (long unsigned int)(data.humidity / 1000),
                       (long unsigned int)data.gas_resistance,
                       data.status);
    #endif
                sample_count++;
    It seems all rigth, I build and the code does not gave any error, but the output is this:
    API name [bme68x_interface_init]: Tutto ok
    API name [bme68x_init]: Tutto ok
    API name [bme68x_set_conf]: Tutto ok
    API name [bme68x_set_heatr_conf]: Tutto ok
    API name [bme68x_set_op_mode]: Tutto ok
    API name [bme68x_get_data] Warning [2] : No new data found
    API name [bme68x_get_data] Warning [2] : No new data found (and it continues with no new data)
    I try to wait a lot, but the result does not change. I do not understand where the problem is. What can I do to solve the problem?
    Is it possible that the sensor is damaged? In that case, how can I understand it?
    Thanks for the help
    11 REPLIES 11
    Re: BME688 no new data found
    Hi Rosso9,
    You could refer attached example code on STM32, compare with your code and run it again.
    Rosso9
    Hi, thanks.
    Where can I find these examples?
    Sorry, I forget to upload attachment.
    You could get it now.
    Rosso9
    I have looked at the example and I think my functions are quite similar, but the code gives back the same error: no new data found.
    I attach my common.c file, if you could give it a look. I use I2C communication (in the function, I use the 7 bit address because the microcontroller wants the 7 bit address).
