    BME688 sensor API
    Rosso9
    Re: BME688 sensor API
    Thanks again for your help.
    I try to modify the common.c file to adapt to my microcontroller. I would like to ask you if the structure is correct (not the single function on the code but the general struscture), because when I built the program I have no problem, but then the code returns error. In particular, init_interface function works correctly, but then init funcrion, set_config function ecc return error -2: communication error
    static const nrf_drv_twi_t i2c_instance = NRF_DRV_TWI_INSTANCE(0);
    BME68X_INTF_RET_TYPE bme68x_i2c_read(uint8_t reg_addr, uint8_t *reg_data, uint32_t len, void *intf_ptr)
    int8_t err = nrf_drv_twi_rx(&i2c_instance, reg_addr, reg_data, len);
    return err;
    BME68X_INTF_RET_TYPE bme68x_i2c_write(uint8_t reg_addr, const uint8_t *reg_data, uint32_t len, void *intf_ptr)
    int8_t err = nrf_drv_twi_tx(&i2c_instance, reg_addr, reg_data, len, false);
    return err;
    void bme68x_delay_us(uint32_t period, void *intf_ptr)
    nrf_delay_us(period);
    int8_t bme68x_interface_init(struct bme68x_dev *bme, uint8_t intf)
    int8_t rslt = BME68X_OK;
    uint8_t reg_addr;
    const uint8_t *reg_data;
    uint32_t len;
    void *intf_ptr;
    if (bme != NULL)
    /* Bus configuration : I2C */
    if (intf == BME68X_I2C_INTF)
    printf("I2C Interface\n");
    dev_addr = BME68X_I2C_ADDR_LOW;
    bme->read = bme68x_i2c_read;
    bme->write = bme68x_i2c_write;
    bme->intf = BME68X_I2C_INTF;
    //here I initialize the I2c component
    const nrf_drv_twi_config_t i2c_instance_config = { .scl = SCL_PIN,
    .sda = SDA_PIN,
    .frequency = NRF_TWI_FREQ_100K,
    .interrupt_priority = 0};
    rslt = nrf_drv_twi_init(&i2c_instance, &i2c_instance_config, NULL, NULL);
    if (rslt)
    printf("Error %d: Initialization of I2C connection failed!\n", rslt);
    //enable I2c instance
    nrf_drv_twi_enable(&i2c_instance);
    bme->delay_us = bme68x_delay_us;
    bme->intf_ptr = &dev_addr;
    bme->amb_temp = 25; /* The ambient temperature in deg C is used for defining the heater temperature */
    else
    rslt = BME68X_E_NULL_PTR;
    return rslt;
    Thanks again
    Rosso9
    I try to risolve the problem of adaptation of common.c files. Now there is something that works but not correctly.
    In the main code, first I search if there are some connected devices through I2C (and I find that there is a device at 0x76, which is the BME688), then I try to use the forced mode configuration example, but here there is the problem. I attach here the output.
    //OUTPUT OF THE PROGRAM
    Starting the program
    TWI device detected at address 0x76.     //(TWI is equivalent to I2C) So the sensor is correctly connected
    INIZIO BME
    I2C Interface
    API name [bme68x_init] Error [-3] : Device not found
    API name [bme68x_set_conf]: Tutto ok
    API name [bme68x_set_heatr_conf]: Tutto ok
    API name [bme68x_set_op_mode]: Tutto ok
    API name [bme68x_get_data]: Tutto ok
    Getting data correctly
    Printing resultsstatus: 128
    Gas index: 0
    Meas index: 0
    Res heat: 128
    Current DAC: 0
    Gas wait period: 0
    Temperatura: 0.80 °C
    Pressione: -1290.20 Pa
    Umidita': 0.0 Gas resistance: 5070.0 O
    API name [bme68x_get_data] Warning [2] : No new data found
    Gas index: 10
    Meas index: 22
    Res heat: 64
    Current DAC: 0
    Gas wait period: 128
    Temperatura: 0.33 °C
    Pressione: 23550.48 Pa
    Umidita': 0.0 Gas resistance: 14202.64
    I do not understand. The sensor is correctly connected, otherwise the microcontroller would not find anything at the adress 0x76.
    But then when I try to initialize the sensor, it returns that the device is not found, but after it looks like as the sensor is connected and it says if it has new datas or no, and in case it sends datas (however, the datas that are sent are obviously wrong!).
    I do not understand where the problem is.
    Thanks for the help
    Hi Rosso,
    The error happens when you don't get correct chip ID.
    What chip ID did you get from BME688?
    Do you have logic analyzer or can read i2c value from your board?
    Rosso9
    Hi again,
    after some troubles, I finally get the correct chip ID value.
    But now I have a different kind of problem.
    The first time I connect to power the sensor and run the program, I have this result:
    I2C InterfaceAPI name [bme68x_interface_init]: Tutto ok
    API name [bme68x_init]: Tutto ok
    I have waited some times but it seems to be blocked in somewhere I do not know.
    If I push the reset button of microcontroller, I obtain a different result:
    INIZIO BME
    Here, I see that the microcontroller is stopped in the bme68x_set_conf, and in particular it cannot exit the do while cicle at line 444 of bme68x.c file (it seems that the code want to put in sleep mode the sensor but it is not able).
    Do you have any idea of why I get these problems? I have not modified the bme68x.c file.
    Hi Rosso,
    Which example code did you refer to?
    Please check your sequence is correct. For example, if you want to get data in foreced mode, you can refer below example.
    https://github.com/BoschSensortec/BME68x-Sensor-API/blob/master/examples/forced_mode/forced_mode.c
    And each function in BME68x API like bme68x_set_heatr_conf, we have return, so you can check whether there is error or not.
    Let me know if you have further questions.
