    BME688 some register can't write
    xiaoheng
    Occasional Visitor
    I am user stm32G070 with spi  connect to bme688, and find the data not correct
    1, 46829, 106.39, -21015.71, 0.00, 82643128.00, 0x80
    2, 49471, 106.39, -21015.71, 0.00, 82643128.00, 0x80
    3, 52113, 106.39, -21015.71, 0.00, 82643128.00, 0x80
    4, 54755, 106.39, -21015.71, 0.00, 82643128.00, 0x80
    5, 57397, 106.39, -21015.71, 0.00, 82643128.00, 0x80
    6, 60039, 106.39, -21015.71, 0.00, 82643128.00, 0x80
    7, 62681, 106.39, -21015.71, 0.00, 82643128.00, 0x80
    8, 65323, 106.39, -21015.71, 0.00, 82643128.00, 0x80
    9, 67965, 106.39, -21015.71, 0.00, 82643128.00, 0x80
    10, 70607, 106.39, -21015.71, 0.00, 82643128.00, 0x80
    then  run the self test check code, and got fail result:
    API name [bme68x_selftest_check] Error [-5] : Self test error
    Self-test failed
     and I found that data[0].idac == 0, it mean that no heater,
    so write the reg 0x5A for a value , and then read it out, the register 0x5A is still 0x00
    the timing waveform is correct, so what can I do?
    Hi xiaoheng,
    The printf log of your "Temperature(deg C), Pressure(Pa), Humidity(%), Gas resistance(ohm), Status" were not correct.
    You could refer attached example code which run on STM32F4, and check whether your migrated BME688 sensor API(https://github.com/BoschSensortec/BME68x-Sensor-API) to your platform successfully?
