    BME688 strange IAQ output with BSEC2
    carmixdev
    I'm developing a IAQ Sensor using BME688 in conjunction with the BSEC 2.0 library on ESP32 board.
    I'm using the sample code provided with the library that detects IAQ and also sense 4 different gases.
    Yet I'm only interested to the IAQ measurement.
    Now I've run the sensor for some days and I've got a strange peaky response in the IAQ readings, it seems a very periodic behavior, with a period every 5 measurements, the interval between a measure and the other is roughly of 10 seconds, then when it reaches the lower bound it stucks for approx 120 seconds and then spikes up.
    I pasted a picture here of the measured IAQ. It seems to me that the correct IAQ is the lower measurement
    Do you have any hint?
    bme/iaq {"IAQ":235.1,"IAQ_accuracy":3,"GAS_R":56612.1}
    bme/iaq {"IAQ":190.9,"IAQ_accuracy":3,"GAS_R":72112.7}
    bme/iaq {"IAQ":157.4,"IAQ_accuracy":3,"GAS_R":78988.0}
    bme/iaq {"IAQ":136.3,"IAQ_accuracy":3,"GAS_R":83387.6}
    bme/iaq {"IAQ":122.8,"IAQ_accuracy":3,"GAS_R":86340.6}
    bme/iaq {"IAQ":236.4,"IAQ_accuracy":3,"GAS_R":56499.7}
    bme/iaq {"IAQ":192.0,"IAQ_accuracy":3,"GAS_R":71930.3}
    bme/iaq {"IAQ":158.0,"IAQ_accuracy":3,"GAS_R":78914.9}
    bme/iaq {"IAQ":137.2,"IAQ_accuracy":3,"GAS_R":83143.9}
    bme/iaq {"IAQ":123.8,"IAQ_accuracy":3,"GAS_R":86079.4}
    bme/iaq {"IAQ":237.8,"IAQ_accuracy":3,"GAS_R":56276.1}
    bme/iaq {"IAQ":193.0,"IAQ_accuracy":3,"GAS_R":71748.9}
    bme/iaq {"IAQ":159.0,"IAQ_accuracy":3,"GAS_R":78696.6}
    bme/iaq {"IAQ":138.0,"IAQ_accuracy":3,"GAS_R":82982.2}
    bme/iaq {"IAQ":124.9,"IAQ_accuracy":3,"GAS_R":85819.6}
    bme/iaq {"IAQ":237.5,"IAQ_accuracy":3,"GAS_R":56424.9}
    bme/iaq {"IAQ":194.8,"IAQ_accuracy":3,"GAS_R":71329.1}
    bme/iaq {"IAQ":160.4,"IAQ_accuracy":3,"GAS_R":78407.4}
    bme/iaq {"IAQ":138.9,"IAQ_accuracy":3,"GAS_R":82821.1}
    bme/iaq {"IAQ":125.1,"IAQ_accuracy":3,"GAS_R":85819.6}
    Hello carmixdev,
    What's the sample rate you configured?
    When you do the test, what is your air environment like?
    The sample rate is the one defined by the macro BSEC_SAMPLE_RATE_HIGH_PERFORMANCE,
    I pasted  the relevant code snippet from my implementation, as of the environment it is a study room, the detected IAQ seems reasonable if you don't consider the "comb" effect 😄
    void setup(void)
    bsec_virtual_sensor_t sensorList[] = {
    BSEC_OUTPUT_RAW_TEMPERATURE,
    BSEC_OUTPUT_RAW_PRESSURE,
    BSEC_OUTPUT_RAW_HUMIDITY,
    BSEC_OUTPUT_RAW_GAS,
    BSEC_OUTPUT_RAW_GAS_INDEX,
    BSEC_OUTPUT_IAQ,
    BSEC_OUTPUT_CO2_EQUIVALENT,
    BSEC_OUTPUT_STABILIZATION_STATUS,
    BSEC_OUTPUT_GAS_ESTIMATE_1,
    BSEC_OUTPUT_GAS_ESTIMATE_2,
    BSEC_OUTPUT_GAS_ESTIMATE_3,
    BSEC_OUTPUT_GAS_ESTIMATE_4
    Serial.begin(115200);
    EEPROM.begin(BSEC_MAX_STATE_BLOB_SIZE + 1);
    if(!bsecInst.begin(BME68X_I2C_ADDR_HIGH, Wire) ||
    !bsecInst.setConfig(bsec_config_selectivity) ||
    !loadState(bsecInst) ||
    !bsecInst.updateSubscription(sensorList, ARRAY_LEN(sensorList), BSEC_SAMPLE_RATE_HIGH_PERFORMANCE))
    checkBsecStatus(bsecInst);
    Hello carmixdev,
    BSEC_SAMPLE_RATE_HIGH_PERFORMANCE sample rate was used in BSEC example code.
    The value of IAQ is affected by the actual air.
