    BME688 wrong temperatura and humidty
    josemartinez
    I'm are using a BME688 in a project to read ambiental data with an ESP32. The problem is that temperature that is reading, the compensated one, is over 3 degrees up than the real and humidity is like a 60% lower. CO2 levels seems to be unrealistic too.
    To try this sensor, I'm using the example "basic_config_state.ino" of arduino library available in GitHub, "BSEC-Arduino-library". With "config/generic_33v_3s_4d/bsec_iaq.txt" configuration.
    I tried to use an offset of 3 degrees to try to compensate it and it seems to improve something. But still exits some error:
    BME688AQMDateTime
    H%CO2H%CO2
    24,845,71334264670413/09/202214:41
    28,451,1642314761713/09/20228:13
    25,739,42180274194113/09/202211:02
    25,238,721592742134213/09/202213:55
    27,853,1654305355014/09/20229:04
    25,447,11754274872514/09/202211:00
    24,738,419232643121915/08/20229:33
    I'm going to capture more data and update this post with it.
    Do you now what is going on? There is a problem with the current configutation? Could you provide me some example to configurate it correctly?
    10 REPLIES 10
    Hi josemartinez,
    Timestamp unit is ns in the code. From your printed information, the timestamp is abnormal.
    int64_t time_stamp; /*!< @brief Time stamp in nanosecond resolution as provided as input [ns] */
