    BME68X API with BME688 - No New Data Found
    I'm using the BM68X API to read data off of a BME688 via a Nordic nRF52840 development kit. The only major changes to the code are the I2C initialization, read, and write functions as well as the delay function. Otherwise the code is mostly the same from the API using the force mode example. However, I'm not able to receive data from the sensor and a no new data error is thrown.
    Below is the terminal output for the various steps to initialize the sensor and attempt to read data. For sequential reads and writes, the index (M) as well as the register and data is written to the terminal. The I2C interface seems to be working but I can't quite tell what the source of the problem is.
    So far I've been able to make the BME280 API work with similar write, read, and delay functions and checked all the logic with a logic analyzer but I'm not sure what to try next. My only concern is that I can't implement a multi-byte read because of limitations with the interface, maximum of 3 bytes, so I just use individual 1 byte reads. This is sufficient for the BME280 API but maybe not the BME68X API.
    ---Interface init.---
    I2C Interface
    ---BME68X init.---
    ---Soft reset---
    ----I2C write----
    Length: 1
    Reg addr e0 - Data b6
    ----I2C Read----
    Reg addr d0
    Length: 1
    Reg data: M: 0 - Data 61
    ----I2C Read----
    Reg addr f0
    Length: 1
    Reg data: M: 0 - Data 1
    ---Get calibration---
    ---Cal: get regs1---
    ----I2C Read----
    Reg addr 8a
    Length: 23
    Reg data: M: 0 - Data 17
    Reg data: M: 1 - Data 67
    Reg data: M: 2 - Data 3
    Reg data: M: 3 - Data 0
    Reg data: M: 4 - Data 70
    Reg data: M: 5 - Data 8c
    Reg data: M: 6 - Data 88
    Reg data: M: 7 - Data d7
    Reg data: M: 8 - Data 58
    Reg data: M: 9 - Data 0
    Reg data: M: 10 - Data 86
    Reg data: M: 11 - Data 29
    Reg data: M: 12 - Data eb
    Reg data: M: 13 - Data fe
    Reg data: M: 14 - Data 1d
    Reg data: M: 15 - Data 1e
    Reg data: M: 16 - Data 0
    Reg data: M: 17 - Data 0
    Reg data: M: 18 - Data d2
    Reg data: M: 19 - Data fb
    Reg data: M: 20 - Data 56
    Reg data: M: 21 - Data f3
    Reg data: M: 22 - Data 1e
    ---Cal: get regs2---
    ----I2C Read----
    Reg addr e1
    Length: 14
    Reg data: M: 0 - Data 3e
    Reg data: M: 1 - Data 2c
    Reg data: M: 2 - Data 35
    Reg data: M: 4 - Data 2d
    Reg data: M: 5 - Data 14
    Reg data: M: 6 - Data 78
    Reg data: M: 7 - Data 9c
    Reg data: M: 8 - Data 68
    Reg data: M: 9 - Data 66
    Reg data: M: 10 - Data e5
    Reg data: M: 11 - Data e8
    Reg data: M: 12 - Data c5
    Reg data: M: 13 - Data 12
    ---Cal: get regs3---
    ----I2C Read----
    Reg addr 0
    Length: 5
    Reg data: M: 0 - Data 2a
    Reg data: M: 1 - Data aa
    Reg data: M: 2 - Data 16
    Reg data: M: 3 - Data 4b
    Reg data: M: 4 - Data 3
    ---Set Config.---
    ---Get op mode---
    ----I2C Read----
    Reg addr 74
    Length: 1
    Reg data: M: 0 - Data 0
    ---Set op mode---
    ----I2C Read----
    Reg addr 74
    Length: 1
    ---Get regs---
    ----I2C Read----
    Reg addr 71
    Length: 5
    Reg data: M: 1 - Data 0
    Reg data: M: 2 - Data 0
    Reg data: M: 4 - Data 0
    ---Set regs2---
    ----I2C write----
    Length: 9
    M: 0 - Reg addr 71 - Data 80
    M: 1 - Reg addr 72 - Data 5
    M: 3 - Reg addr 73 - Data 0
    M: 5 - Reg addr 74 - Data 44
    M: 7 - Reg addr 75 - Data 0
    ---Heater Config---.
    Set op mode
    ----I2C Read----
    Reg addr 74
    Length: 1
    ----I2C write----
    Length: 1
    Reg addr 5a - Data 6a
    ----I2C write----
    Length: 1
    Reg addr 64 - Data 59
    ----I2C Read----
    Reg addr 70
    Length: 2
    Set regs
    ----I2C write----
    Length: 3
    M: 0 - Reg addr 70 - Data 8
    M: 1 - Reg addr 71 - Data 0
    ---Set op mode---
    ----I2C Read----
    Reg addr 74
    Length: 1
    ---Already asleep---
    ----I2C write----
    Length: 1
    Reg addr 74 - Data 1
    Read field data
    ----I2C Read----
    Reg addr 1d
    Length: 17
    Reg data: M: 2 - Data 80
    Reg data: M: 5 - Data 80
    Reg data: M: 6 - Data 0
    Reg data: M: 7 - Data 0
    Reg data: M: 8 - Data 80
    Reg data: M: 10 - Data 80
    Reg data: M: 11 - Data 0
    Reg data: M: 12 - Data 0
    Reg data: M: 13 - Data 0
    Reg data: M: 14 - Data 4
    Reg data: M: 15 - Data 0
    Reg data: M: 16 - Data 4
    API name [bme68x_get_data]  Warning [2] : No new data found
    9 REPLIES 9
    Hello Value_Judgement,
    There was MCU reference code in another ticket, you could refer it from here:https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BME680-with-BSEC-produces-on-0-0s-even-a...
    I doubled the stack size but the problem persisits.
    When data is written to registers, how much permenance do they have? I've tried reading back the same written values just after they're written but I don't ncessarily get the same values back. There's delays associated with printing out the text but I'm not sure if written values last for milliseconds, seconds, or stay until they're changed.
    For "I've tried reading back the same written values just after they're written but I don't ncessarily get the same values back.", first you should check your I2C read, write function, and second you should ensure that the registers being operated have read and write permissions.
    I've been able to verify that all the I2C writes are correct using a logic analyzer, see attached PDF. And I can take the same read, write, and delay functions to the BME280 API and that code works correctly. The only difference between the two is that the write function for the 688 account for multiple writes to different addresses.
    Upon reviewing the registers, some of the writes are to bit positions that are reserved. Example:
    M: 0 - Reg addr 0x71 - Data 0x80 (0b10000000)
    Register 0x71 is reserved for bits 5, 6 , and 7 but I haven't changed any of the configuration settings and they're copied verbatim from the forced mode example code.
    Can you provide an example of the I2C writes and reads for that example so I can compare?
