    BME68X API with BME688 - No New Data Found
    I'm using the BM68X API to read data off of a BME688 via a Nordic nRF52840 development kit. The only major changes to the code are the I2C initialization, read, and write functions as well as the delay function. Otherwise the code is mostly the same from the API using the force mode example. However, I'm not able to receive data from the sensor and a no new data error is thrown.
    Below is the terminal output for the various steps to initialize the sensor and attempt to read data. For sequential reads and writes, the index (M) as well as the register and data is written to the terminal. The I2C interface seems to be working but I can't quite tell what the source of the problem is.
    So far I've been able to make the BME280 API work with similar write, read, and delay functions and checked all the logic with a logic analyzer but I'm not sure what to try next. My only concern is that I can't implement a multi-byte read because of limitations with the interface, maximum of 3 bytes, so I just use individual 1 byte reads. This is sufficient for the BME280 API but maybe not the BME68X API.
    ---Interface init.---
    I2C Interface
    ---BME68X init.---
    ---Soft reset---
    ----I2C write----
    Length: 1
    Reg addr e0 - Data b6
    ----I2C Read----
    Reg addr d0
    Length: 1
    Reg data: M: 0 - Data 61
    ----I2C Read----
    Reg addr f0
    Length: 1
    Reg data: M: 0 - Data 1
    ---Get calibration---
    ---Cal: get regs1---
    ----I2C Read----
    Reg addr 8a
    Length: 23
    Reg data: M: 0 - Data 17
    Reg data: M: 1 - Data 67
    Reg data: M: 2 - Data 3
    Reg data: M: 3 - Data 0
    Reg data: M: 4 - Data 70
    Reg data: M: 5 - Data 8c
    Reg data: M: 6 - Data 88
    Reg data: M: 7 - Data d7
    Reg data: M: 8 - Data 58
    Reg data: M: 9 - Data 0
    Reg data: M: 10 - Data 86
    Reg data: M: 11 - Data 29
    Reg data: M: 12 - Data eb
    Reg data: M: 13 - Data fe
    Reg data: M: 14 - Data 1d
    Reg data: M: 15 - Data 1e
    Reg data: M: 16 - Data 0
    Reg data: M: 17 - Data 0
    Reg data: M: 18 - Data d2
    Reg data: M: 19 - Data fb
    Reg data: M: 20 - Data 56
    Reg data: M: 21 - Data f3
    Reg data: M: 22 - Data 1e
    ---Cal: get regs2---
    ----I2C Read----
    Reg addr e1
    Length: 14
    Reg data: M: 0 - Data 3e
    Reg data: M: 1 - Data 2c
    Reg data: M: 2 - Data 35
    Reg data: M: 4 - Data 2d
    Reg data: M: 5 - Data 14
    Reg data: M: 6 - Data 78
    Reg data: M: 7 - Data 9c
    Reg data: M: 8 - Data 68
    Reg data: M: 9 - Data 66
    Reg data: M: 10 - Data e5
    Reg data: M: 11 - Data e8
    Reg data: M: 12 - Data c5
    Reg data: M: 13 - Data 12
    ---Cal: get regs3---
    ----I2C Read----
    Reg addr 0
    Length: 5
    Reg data: M: 0 - Data 2a
    Reg data: M: 1 - Data aa
    Reg data: M: 2 - Data 16
    Reg data: M: 3 - Data 4b
    Reg data: M: 4 - Data 3
    ---Set Config.---
    ---Get op mode---
    ----I2C Read----
    Reg addr 74
    Length: 1
    Reg data: M: 0 - Data 0
    ---Set op mode---
    ----I2C Read----
    Reg addr 74
    Length: 1
    ---Get regs---
    ----I2C Read----
    Reg addr 71
    Length: 5
    Reg data: M: 1 - Data 0
    Reg data: M: 2 - Data 0
    Reg data: M: 4 - Data 0
    ---Set regs2---
    ----I2C write----
    Length: 9
    M: 0 - Reg addr 71 - Data 80
    M: 1 - Reg addr 72 - Data 5
    M: 3 - Reg addr 73 - Data 0
    M: 5 - Reg addr 74 - Data 44
    M: 7 - Reg addr 75 - Data 0
    ---Heater Config---.
    Set op mode
    ----I2C Read----
    Reg addr 74
    Length: 1
    ----I2C write----
    Length: 1
    Reg addr 5a - Data 6a
    ----I2C write----
    Length: 1
    Reg addr 64 - Data 59
    ----I2C Read----
    Reg addr 70
    Length: 2
    Set regs
    ----I2C write----
    Length: 3
    M: 0 - Reg addr 70 - Data 8
    M: 1 - Reg addr 71 - Data 0
    ---Set op mode---
    ----I2C Read----
    Reg addr 74
    Length: 1
    ---Already asleep---
    ----I2C write----
    Length: 1
    Reg addr 74 - Data 1
    Read field data
    ----I2C Read----
    Reg addr 1d
    Length: 17
    Reg data: M: 2 - Data 80
    Reg data: M: 5 - Data 80
    Reg data: M: 6 - Data 0
    Reg data: M: 7 - Data 0
    Reg data: M: 8 - Data 80
    Reg data: M: 10 - Data 80
    Reg data: M: 11 - Data 0
    Reg data: M: 12 - Data 0
    Reg data: M: 13 - Data 0
    Reg data: M: 14 - Data 4
    Reg data: M: 15 - Data 0
    Reg data: M: 16 - Data 4
    API name [bme68x_get_data]  Warning [2] : No new data found
    9 REPLIES 9
    Issue resolved. The I2C writes needed two bytes at a time, address and data value, instead of sequential writes with one byte at a time, alternating between register address and value. Stated in the datasheet but I just took the wrong implementation with the Nordic SDK I2C write function.
    Hello Value_Judgement,
    Good news.
    Yes, I2C write and read had different time sequence.
    Hi, I've got the same problme. Please, could you share the commn.c file where you have written the read write i2c functions?
    I'm sorry to ask, but I cannot resolve the problem.
    Your common.c should be something similar to the API example but the problem is likely in your I2C write/read functions. Make sure you're actually writing and reading the right data to and from the right registers in the right format (page 46 in the datasheet).
    Yeah, I have looked at pag 46 of the datasheet and I think I respect what they ask, but still not working.
    Could you let me see your bme68x_i2c_write and bme68x_i2c_read functions, please? I do not know how to make them in a different way
