01-13-2023 02:18 AM
Hello
I have a question about the following registers on the BME680/688.
Gas control register / Res_heat_x (63. .5Ah)
The "Res_heat_x" is the resistance value of the target heater.
If the calculated value is 177, is the unit of this value "177ohm"?
Or is it "177kilo-ohm"?
Please respond.
01-30-2023 07:41 AM
Hi EM-1,
No, gas resistance value was get by calling bme68x_get_data(), you could see this example code how to get ohm unit gas resistance value.
https://github.com/boschsensortec/BME68x-Sensor-API/blob/master/examples/forced_mode/forced_mode.c
