06-05-2019 01:49 AM
I've been working with the BME680 and BSEC software. I have a number of examples working with both BSEC and no BSEC. However when I try to add in the ability to save the IAQ history I cannot get the "basic_config_state.ino" example to compile.
Errors are created during the "compiling Sketch" operations.
Does anyone have a link to the eeprom.h the example is expecting?
John
basic_config_state:23:44: error: no matching function for call to 'EEPROMClass::begin(int)'
EEPROM.begin(BSEC_MAX_STATE_BLOB_SIZE + 1); // 1st address for the length
06-12-2019 07:44 PM
I believe this example code was tested with an ESP8266 MCU, which has such an EEPROM library built-in its toolchain.
I am not sure exactly which MCU or board you are using, is it possible that you could find a similar EEPROM library for your board, or some alternative non-volatile memory (e.g. SD card, etc.)?
