10-28-2023 12:52 AM
I have a BMI 270 chip that appears to have a different sensitivity scalar in one direction compared to the other.
I tested for this with the following procedure:
Doing this test results in a consistent error of about 2 degrees, across the 5 tests I performed.
If instead I were to vibrate the BMI on the same fixture for the same duration as the test, the error results in about 0.2 degrees, which appears to indicate that this error is a result of the turning in particular.
The other BMI's I have tested with this exact procedure usually end up with 0.2 to 0.4 degrees error.
So this leads to my questions:
11-07-2023 08:12 AM
Hi Johnny,
Did you design a project with BMI270? What application is BMI270 used for?
For your test, what are your requirements? Can you provide a detailed description of your process and attach data?
