    BMI088 Accelerometer read "feature"
    dl1uj
    I started to write a very small driver for the BMI088. While the gyroscope is working like expected, The accelerometer has a stange “feature”. Writing to it works fine, but reading any register gives the value of the previous read request. To read the xyz values I have to write twice to the register 0x12 to get the proper axis values like this:
    ACC_ENABLE();
    spi_transfer(ACC_X_LSB_12 | 0x80); // Start register read
    spi_transfer(ACC_X_LSB_12 | 0x80); // Again start register read (why ever!)
    ax = spi_transfer(0xFF);   ax += spi_transfer(0xFF) << 8;
    ay = spi_transfer(0xFF);   ay += spi_transfer(0xFF) << 8;
    az = spi_transfer(0xFF);   az += spi_transfer(0xFF) << 8;
    ACC_DISABLE();
    With this workaround the raw values for the IMU are fine. Does anyone know why the reading result is shifted by one operation? Looks like it´s caused by the FIFO, but I don´t write anything to it. Any help is welcome. Doing almost the same with the BMI055 worked without any problems.
    Greetings from Germany
    Udo
    Vincent
    Re: BMI088 Accelerometer read "feature"
    For BMI088 accel,  the default interface is configged as I2C,  you need a dummy read of SPI to switch to SPI bus first.
    Also you need a dummy byte during SPI read from the accel part.
    You can refer to our BMI088 API on Github from following link:
    https://github.com/BoschSensortec/BMI08x-Sensor-API
    gigamonte
    When selecting SPI for BMI088 accelerometer, does the datasheet indicate that the user has an option between toggling the PS pin and sending a dummy read or do both need to be done? It's not clear.
    Hello gigamonte,
    SPI CS pin and dummy data for BMI088 are necessary.
