02-08-2023 05:26 PM - edited 02-08-2023 05:28 PM
Hi Bosch Team,
I am facing an issue that ralates to accelerate FIFO. It seems like the data is correct enough all the time, but when I try to halt reading FIFO buffer for a while then the issue happens.
25036 X135 Y-154 Z11205
25041 X136 Y-158 Z11206
25045 X135 Y-164 Z11204
25050 X135 Y-165 Z11203
25054 X131 Y-169 Z11201
25059 X129 Y-169 Z11197
25063 X128 Y-166 Z11195
25068 X129 Y-161 Z11194
25072 X131 Y-157 Z11192
25077 X133 Y-150 Z11193
25081 X134 Y-151 Z11193
25086 X133 Y-148 Z11194
25090 X135 Y-159 Z11196
25095 X137 Y-158 Z11200
25099 X137 Y-165 Z11203
25103 X138 Y0 Z0
25108 X138 Y0 Z0
25113 X126 Y-161 Z11195
25118 X125 Y-157 Z11195
25122 X123 Y-158 Z11192
25127 X133 Y-160 Z11202
25131 X131 Y-148 Z11197
I mean "correct enough" because there is sometimes the data output is 0 on Y and Z and it's totally incorrect.
After halting the reading data from FIFO buffer, then read it back, the data is not correct anymore after hundred miliseconds
32065 X131 Y-156 Z11199
32071 X134 Y-159 Z11202
32075 X131 Y-165 Z11200
32080 X133 Y-164 Z11202
32084 X133 Y-163 Z11198
32089 X134 Y-160 Z11199
32093 X135 Y-159 Z11195
32098 X135 Y-157 Z11193
32102 X136 Y-156 Z11190
32107 X134 Y-153 Z11190
32111 X134 Y-151 Z11192
32115 X132 Y-147 Z11197
32120 X133 Y-145 Z11201
32124 X135 Y-143 Z11204
32129 X134 Y-145 Z11204
32133 X137 Y-149 Z11207
32138 X135 Y-154 Z11205
32142 X136 Y-158 Z11206
32147 X135 Y-164 Z11204
32151 X135 Y-165 Z11203
32156 X131 Y-169 Z11201
32160 X129 Y-169 Z11197
32165 X128 Y-166 Z11195
32169 X129 Y-161 Z11194
32174 X131 Y-157 Z11192
32178 X133 Y-150 Z11193
32183 X134 Y-151 Z11193
32187 X133 Y-148 Z11194
32192 X135 Y-159 Z11196
32196 X137 Y-158 Z11200
32200 X137 Y-165 Z11203
32205 X138 Y0 Z0
32210 X138 Y0 Z0
32220 X123 Y-158 Z11192
32225 X129 Y-156 Z11196
32230 X129 Y-159 Z11197
32234 X131 Y-160 Z11201
32239 X132 Y-162 Z11204
32243 X131 Y-161 Z11207
32248 X130 Y-161 Z11207
32252 X129 Y-160 Z11209
32257 X126 Y-159 Z11205
32261 X126 Y-154 Z11201
32266 X128 Y-155 Z11195
32270 X131 Y-154 Z11192
32275 X133 Y-156 Z11190
32279 X139 Y-154 Z11192
32284 X137 Y-154 Z11191
32288 X141 Y-150 Z11196
32293 X138 Y-152 Z11193
32297 X140 Y-154 Z11196
32302 X136 Y-158 Z11195
32306 X138 Y-159 Z11196
32310 X137 Y-161 Z11195
32315 X142 Y-159 Z11199
32319 X142 Y-158 Z11198
32324 X144 Y-154 Z11201
32328 X141 Y-153 Z11196
32333 X140 Y-149 Z11196
32337 X134 Y-148 Z11189
32342 X134 Y-147 Z11190
32346 X131 Y-146 Z11189
32351 X132 Y-147 Z11193
32355 X134 Y-149 Z11193
32360 X135 Y-152 Z11196
32364 X139 Y-155 Z11195
32369 X138 Y-155 Z11197
32373 X-120 Y11200 Z-30332
32379 X-120 Y11200 Z-30332
32385 X136 Y-157 Z11197
32389 X134 Y-155 Z11199
32394 X131 Y-155 Z11196
32398 X-31611 Y131 Z-160
32404 X-31611 Y131 Z-160
32409 X133 Y-157 Z11197
32414 X134 Y-155 Z11199
32419 X131 Y-155 Z11196
32423 X-31611 Y131 Z-160
32428 X-31611 Y131 Z-160
32433 X133 Y-157 Z11197
32438 X134 Y-155 Z11199
32443 X131 Y-155 Z11196
32447 X-31611 Y131 Z-160
32452 X-31611 Y131 Z-160
32458 X133 Y-153 Z11196
32463 X133 Y-155 Z11199
32467 X131 Y-155 Z11196
32471 X-31611 Y131 Z-160
32476 X-31611 Y131 Z-160
32482 X133 Y-153 Z11196
32487 X133 Y-155 Z11199
32491 X131 Y-155 Z11196
32496 X-31611 Y131 Z-160
32500 X-31611 Y131 Z-160
32506 X133 Y-153 Z11196
32511 X133 Y-155 Z11199
32515 X131 Y-155 Z11196
32520 X-31611 Y131 Z-160
32525 X-31611 Y131 Z-160
32530 X133 Y-153 Z11192
32535 X134 Y-155 Z11199
32539 X131 Y-155 Z11196
32544 X-31611 Y131 Z-160
32549 X-31611 Y131 Z-160
32554 X134 Y-153 Z11192
32559 X134 Y-155 Z11199
32564 X131 Y-155 Z11196
32568 X-31611 Y131 Z-160
32573 X-31611 Y131 Z-160
32578 X134 Y-153 Z11192
32583 X134 Y-155 Z11199
32588 X131 Y-155 Z11196
32592 X-31611 Y131 Z-160
32597 X-31611 Y131 Z-160
32603 X134 Y-150 Z11192
32607 X133 Y-155 Z11199
32612 X131 Y-155 Z11196
32616 X-31611 Y131 Z-160
32621 X-31611 Y131 Z-160
32627 X133 Y-150 Z11192
32632 X133 Y-155 Z11199
32636 X131 Y-155 Z11196
32641 X-31611 Y131 Z-160
32645 X-31611 Y131 Z-160
I can solve this issue by soft reset, load config file, set measurement config, etc...as the same at the first time I initialize the sensor.
But I do not prefer this approach and tried to reset FIFO by issue the set watermark command but it did not work.
The data is raw, mean LSB. Sensor is configured to water mark iterrupt = 200, ODR=12.5Hz, range=3g, extract 1 frame per time.
Any suggestion to find the root cause is appreciated.
Thanks and Regards
02-09-2023 03:39 AM
Hi huytung1501,
When your host received FIFO watermark interrupt, how many FIFO data has the host read?
And why did you do the operation "halting the reading data from FIFO buffer, then read it back" in your application?
