    BMI088 Sensing Axes
    aswang
    BMI088 Sensing Axes
    Is the sensing axes origin at the center of the top face of the sensor housing (Figure 11), with tolerance +/- 0.05 mm? Also, where might I find the error tolerance for the sensor axes orientation? Thank you!
    Tags (3)
    o_o
    Contributor
    Re: BMI088 Sensing Axes
    Hi Aswang,
    The alignment error for the accelerometer is typically <0.5 degrees and cross-axis sensitivity <0.5%.
    For the gyroscope, alignment error is not specified and cross-axis sensitivity is typically <1%.
    The actual center point of each axis is not specified within the package. However, the motion required for this to have a significant impact would be outside of the sensing range.
    o_o
