    BMI088 and Application Board 3.0 COINES SDK. Communication failure
    FIRAT_SARP
    Hi, I am trying to get data from the BMI088 with the Application Board 3.0 and the COINES SDK.
    In this repository: Bosch BMI08x SensorAPI, I have tried nearly everything. I even tried forks and older releases. In the repository, only bmi088-anymotion/accel_fifo_watermark works correctly. Other examples are giving errors, like the ones below. The bmi08x/accel_fifo_full and gyro_fifo_watermark examples work randomly; they sometimes work and sometimes don't.
    I have seen previous questions similar to this, but they didn't get an answer.
    f@f-ASUS-TUF-Gaming-A15-FA507XI-FA507XI:~$ cat /dev/ttyACM0
    I2C Interface
    bmi08g_init Error [-2] : Communication failure
    init_bmi08 Error [-2] : Communication failure
    Accel FIFO full interrupt data
    I2C Interface
    I2C Interface
    Uploading config file!
    bmi08g_set_power_mode Error [-2] : Communication failure
    bmi08g_set_meas_conf Error [-2] : Communication failure
    Iteration: 1
    FIFO buffer size: 1024
    FIFO length available: 1008
    Requested data frames before parsing: 100
    Parsed accelerometer frames: 100
    Frame_Count, X, Y, Z
    0, 94, -98, 1354
    1, 100, -96, 1361
    2, 105, -102, 1355
    3, 95, -101, 1350
    4, 100, -94, 1347
    5, 85, -102, 1355
    6, 97, -100, 1347
    Hi FIRAT_SARP,
    Thank for your inquiry.
    Make sure you have run the scripts(update_bootloader.bat, update_coines_bridge_flash_fw.bat, update_dd_fw.bat) in the Coines installation directory, upgraded the firmware to your application board, and then try again.
