    BMI088 sensor time question
    ysqcn
    Hi
    From BMI088 spec, only accel stream has sensor time, but gyro doesn't have.
    Any reason that gyro doesn't have?
    Hi ysqcn,
    There was data synchronization application note for your reference. After accel, gyro data synchronization, you could use accel sensor time.
    https://www.bosch-sensortec.com/media/boschsensortec/downloads/application_notes_1/bst-mis-an006.pdf
    ysqcn
    If accel and gyro are in sychronized mode,  they must run at the same rate?
    Hi ysqcn,
    The BMI088 AN006 document explains how to synchronize the data of accel and gyro, which is different from the understanding of setting the same ODR.
