Could you let me know the difference of feature between the IMUs?
- Resolution (mainly Gyroscope)
- stability (no drift)
- Best BLT values (lowest Power consumption, mainly at continuously data reading)
- etc.
I saw you have another question about those sensors, hope we can address them in one place not different location.
Here i will give some information which is public, the other information you interesting are covered by NDA. so you need contact your local FAE for more information.
Sensors | resolution (gyro) | power under normal mode | stability (number under NDA) | offset | interface | pin compatible |
BMI160 | 16 bits | 925uA | OK | +-3 dps | I2C, SPI | Yes |
BMI270 | 16 bits | 650uA | good | +-0.5dps | I2C, SPI | Yes |
BMI263 | 16 bits | 650uA | good | +-0.5dps | I3C,I2C, SPI | Yes |
BMI261 | 16 bits | 650uA | good | +-0.5dps | I2C, SPI | Yes |
BMI260 | 16 bits | 650uA | good | +-0.5dps | I2C, SPI | Yes |
BMI090L | 16 bits | 5mA | Best | +-1dps | I2C, SPI | No |
Hello Vincent,
you can address them in one place. I thougth it would have been better to have diffrent postes for certain questions.
Next time I will open only one post.
Greetings Patrik
What is the exact definition of "stability" (column) in this content?
It is the bias stability or we called Allan Variance.
Those detail number we will only provide under NDA.
