09-22-2021 02:32 PM
Using the driver download from the URL above.
Bug occurred while changing accelero power mode from normal mode to low power mode.
I found that the pre_filter length is not match to the register. Function shows as below:
09-23-2021 04:10 AM
Hello ToAWrong,
Thank for your remind.
The code should be modified like this:
uint16_t pre_filter = 0;
10-16-2021 02:44 PM
