    BMI160 Driver - Can't configure FIFO to be headerless
    dtang
    Hi There:
      I'm working with the driver from Github, trying to capture just Accelerometer data from the FIFO in headerless mode, and I've noticed that in the current driver code it's not possible to place the BMI160 into headerless mode.  Thee problem is in bmi160_set_fifo_config() on line 2248: data |= fifo_config;
           rslt = bmi160_get_regs(reg_addr, &data, BMI160_ONE, dev);
            if (rslt == BMI160_OK)
                if (fifo_config > 0)
                    if (enable == BMI160_ENABLE)
                        data = data | fifo_config; //Problem is on this line
                    else
                        data = data & (~fifo_config);
                /* write fifo frame content configuration*/
                rslt = bmi160_set_regs(reg_addr, &data, BMI160_ONE, dev);
    As shown in the code above, the configuration that gets sent to the BMI FIFO register is an OR of the current configuration and the incoming fifo_config requested.  Since Headerless mode is achieved by clearing a bit that is set by default, we can never actually clear this bit.  My proposed woraround is to always use the unaltered incoming config without the logical OR of the previously set state:
    data = fifo_config;
    This will require to user to set the expected configuration on every FIFO config change, but I don't think that's too much to ask.
    thanks
    Dan
    Hello dtang,
    The logic of this code is to clear bits before configuring registers.
