Hi all,
I encountered a strange issue in BMI160 with nordic 52840 mcu. (on a customed board)
The situation looks like this:
1.The mcu has no problem receving irq like STEP_DETECT_INT, DOUBLE_TAP_INT, and the register values of 0x1C-0x1F are correctly displayed.
2. However, when I try to set irqs like LOW_G_INT, HiGH_G_INT, SLOW_NO_MOTION_INT, I can see irqs arriving in my interrupt handler, but the register values of 0x1C-0x1F are always zero.
This can be quite problematic, since I have no clue which interrups are triggered.
for setting low-g interrupt, my code looks like this
int_config.int_type = BMI160_ACC_LOW_G_INT;// Choosing LOW G/fall detection interrupt
int_config.int_type_cfg.acc_low_g_int.low_data_src=BMI160_ENABLE;//
int_config.int_type_cfg.acc_low_g_int.low_en = BMI160_ENABLE;//
int_config.int_type_cfg.acc_low_g_int.low_mode = BMI160_ENABLE;//
int_config.int_type_cfg.acc_low_g_int.low_hyst = BMI160_ENABLE;//
int_config.int_type_cfg.acc_low_g_int.low_dur = low_dur; // [ms] ((n+1) * 2.5) PREV=50
int_config.int_type_cfg.acc_low_g_int.low_thres = low_thres; // [mg] (n * 7.81) PREV=96
bmi160_set_int_config(&int_config, &sensor); /* sensor is an instance of the structure bmi160_dev */
fall_detected = false;
I'm pretty sure I followed every guideline from here https://github.com/BoschSensortec/BMI160_driver
What could possibly be wrong here? Is it possible that it has something to do with HW schematic?
Any feedback will be appreciated.
Thank you!
Hello potter1234,
There was another ticket that had same TAP feature usage with you.
You could refer this ticket.
https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/bmi160-tap-detection/td-p/21749
What I've been struggling has nothing to do with tap at all.
My question is I can see LOW_G_INT, HiGH_G_INT, SLOW_NO_MOTION_INT, irqs firing, but the register values of 0x1C-0x1F are always zero.
In this case, I can't tell which interrupt is actually firing and I really need to distinguish them.
Hello potter1234,
It was a reference code that run well. When MCU received HW interrupt signal, then read non-zero 0x1C-0x1F register values. For your reference to compare with you code.
