    [BMI160] Register values always zero
    potter1234
    Hi all,
    I encountered a strange issue in BMI160 with nordic 52840 mcu. (on a customed board)
    The situation looks like this:
    1.The mcu has no problem receving irq like STEP_DETECT_INT, DOUBLE_TAP_INT, and the register values of 0x1C-0x1F are correctly displayed.
    2. However, when I try to set irqs like LOW_G_INT, HiGH_G_INT, SLOW_NO_MOTION_INT, I can see irqs arriving in my interrupt handler, but the register values of 0x1C-0x1F are always zero.
    This can be quite problematic, since I have no clue which interrups are triggered.
    for setting low-g interrupt, my code looks like this
    int_config.int_type = BMI160_ACC_LOW_G_INT;// Choosing LOW G/fall detection interrupt
    int_config.int_type_cfg.acc_low_g_int.low_data_src=BMI160_ENABLE;//
    int_config.int_type_cfg.acc_low_g_int.low_en = BMI160_ENABLE;//
    int_config.int_type_cfg.acc_low_g_int.low_mode = BMI160_ENABLE;//
    int_config.int_type_cfg.acc_low_g_int.low_hyst = BMI160_ENABLE;//
    int_config.int_type_cfg.acc_low_g_int.low_dur = low_dur; // [ms] ((n+1) * 2.5) PREV=50
    int_config.int_type_cfg.acc_low_g_int.low_thres = low_thres; // [mg] (n * 7.81) PREV=96
    bmi160_set_int_config(&int_config, &sensor); /* sensor is an instance of the structure bmi160_dev */
    fall_detected = false;
    I'm pretty sure I followed every guideline from here https://github.com/BoschSensortec/BMI160_driver
    What could possibly be wrong here?  Is it possible that it has something to do with HW schematic?
    Any feedback will be appreciated.
    Thank you!
    Re: [BMI160] Register values always zero
    Hello potter1234,
    There was another ticket that had same TAP feature usage with you.
    You could refer this ticket.
    https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/bmi160-tap-detection/td-p/21749
    potter1234
    What I've been struggling has nothing to do with tap at all.
    My question is I can see LOW_G_INT, HiGH_G_INT, SLOW_NO_MOTION_INT,  irqs firing, but the register values of 0x1C-0x1F are always zero.
    In this case, I can't tell which interrupt is actually firing and I really need to distinguish them.
    Hello potter1234,
    It was a reference code that run well. When MCU received HW interrupt signal, then read non-zero 0x1C-0x1F register values. For your reference to compare with you code.
