    BMI160 Roll And Pitch Values Stability
    MehmetDemir
    I am using the BMI160 sensor with NodeMcu over I2C. The project that i'm trying to do is, obtaining the roll and pitch values from the sensors. After i get roll and pitch values from sensors i'll obtain the inclination.
    My problem is, values that the sensor provide me are not stable, even if i doesn't move the BMI160, there can be inconsistency between obtained values. For example in the first read for the roll value is "-12.62" and in the second read the value is "-12.55".
    So i wonder if those values are fine according to sensitivity of the sensor or am I doing something wrong, also are there anything that i can do for keep the values more stable?
    Please see the used code below (The code is derived from the : https://makers-with-myson.blog.ss-blog.jp/2020-06-14).
    #include <Wire.h>
    #include <math.h>
    #include <BMI160Gen.h>
    #define PRINT_PROCESSING
    #define BAUDRATE 9600
    #define SENSE_RATE 100
    #define GYRO_RANGE 2000
    #define ACCL_RANGE 16
    #define SENSOR1 0x69
    #define deg_to_rad(a) (a/180*M_PI)
    #define rad_to_deg(a) (a/M_PI*180)
    float convertRawGyro(int gRaw) {
    // ex) if the range is +/-500 deg/s: +/-32768/500 = +/-65.536 LSB/(deg/s)
    float lsb_omega = float(0x7FFF) / GYRO_RANGE;
    return gRaw / lsb_omega; // deg/sec
    float convertRawAccel(int aRaw) {
    // ex) if the range is +/-2g ; +/-32768/2 = +/-16384 LSB/g
    float lsb_g = float(0x7FFF) / ACCL_RANGE;
    return aRaw / lsb_g;
    static float gyro_roll = 0, gyro_pitch = 0, gyro_yaw = 0;
    static float comp_roll = 0, comp_pitch = 0;
    static unsigned long last_mills = 0;
    void print_roll_pitch()
    // read raw accl measurements from device
    int rawXAcc, rawYAcc, rawZAcc; // x, y, z
    BMI160.readAccelerometer(rawXAcc, rawYAcc, rawZAcc);
    float accX = convertRawAccel(rawXAcc);
    float accY = convertRawAccel(rawYAcc);
    float accZ = convertRawAccel(rawZAcc);
    float rad_a_roll = atan2(accY, accZ);
    float rad_a_pitch = atan2(-accX, sqrt(accY*accY + accZ*accZ));
    float accl_roll = rad_to_deg(rad_a_roll);
    float accl_pitch = rad_to_deg(rad_a_pitch);
    // read raw gyro measurements from device
    int rawRoll, rawPitch, rawYaw; // roll, pitch, yaw
    BMI160.readGyro(rawRoll, rawPitch, rawYaw);
    float omega_roll = convertRawGyro(rawRoll);
    float omega_pitch = convertRawGyro(rawPitch);
    float omega_yaw = convertRawGyro(rawYaw);
    unsigned long cur_mills = micros();
    unsigned long duration = cur_mills - last_mills;
    last_mills = cur_mills;
    double dt = duration / 1000000.0; // us->s
    if (dt > 0.1) return;
    // Gyro data
    gyro_roll += omega_roll * dt; // (ms->s) omega x time = degree
    gyro_pitch += omega_pitch * dt;
    gyro_yaw += omega_yaw * dt;
    // Complementary filter data
    comp_roll = 0.93 * (comp_roll + omega_roll * dt) + 0.07 * accl_roll;
    comp_pitch = 0.93 * (comp_pitch + omega_pitch * dt) + 0.07 * accl_pitch;
    #ifdef PRINT_PROCESSING
    static int n = 0;
    if (n != 50) {
    ++n; return;
    n = 0;
    Serial.print(comp_roll);
    Serial.print(",");
    Serial.print(comp_pitch);
    Serial.print(",");
    #endif
    Serial.println();
    void setup() {
    Serial.begin(BAUDRATE);
    BMI160.begin(BMI160GenClass::I2C_MODE);
    BMI160.setGyroRate(SENSE_RATE);
    BMI160.setAccelerometerRate(SENSE_RATE);
    BMI160.setGyroRange(GYRO_RANGE);
    BMI160.setAccelerometerRange(ACCL_RANGE);
    BMI160.begin(BMI160GenClass::I2C_MODE, SENSOR1);
    BMI160.setXAccelOffset(0);
    BMI160.setYAccelOffset(0);
    BMI160.setZAccelOffset(0);
    BMI160.setXGyroOffset(0);
    BMI160.setYGyroOffset(0);
    BMI160.setZGyroOffset(0);
    delay(100);
    /* Set kalman and gyro starting angle */
    float accX = convertRawAccel(rawXAcc) + 0.01;
    float accY = convertRawAccel(rawYAcc) + 0.01;
    float accZ = convertRawAccel(rawZAcc) + 0.01;
    float roll = rad_to_deg(atan(accY / accZ));
    float pitch = rad_to_deg(atan(-accX / sqrt(accY * accY + accZ * accZ)));
    // Set starting angle
    gyro_roll = comp_roll = roll;
    gyro_pitch = gyro_pitch = pitch;
    void loop() {
    print_roll_pitch();
    Any kind of information is appreciated
    Mehmet
    Jet
    Occasional Contributor
    Hi Sir:
          Could you offer the raw data and your setting to us ?
         When no movement, noise or temperature change will affect the sensor data as well. And based on the different ODR and filter setting, noise also is different.
    Hi Jet, thanks for reply. Setting of circuit in the attachment.
    What can i do to reduce noise? Also if i use long cable to connect the sensor, would that effect the noise factor? And lastly, i'm plannig on connecting the multiplexer to control multiple sensors, would that causes any problem in terms of noise factor?
    Jet
    Hi Sir:
         You should reduce noise by software and/or hardware filter. Please see the datasheet of BMI160 2.4 Data processing to know how to set hardware filter.
         And you also can achieve this feature by your own algorithm.
         If you use long cable to connect the sensor and transmit and receive data, it is easy to be interfered and lead to the signal quality unstable.
         Long cable is connected between sensor and host is not recommended.
         Or if it is inevitable, you might try to add a resistance close to host between them to form impedance matching circuit and then observe the results.
         The impedance matching problematic is only based on experience to be suggested, I am not sure that it is useful for your project.
          Hopefully, it can help you.
