    BMI160 Significant motion interrupt
    Marta
    I want to set an interruption with significant motion detector using BMI160. It works with accelerometer in normal mode and gyro in suspend mode, but I want to use it with accelerometer in low power mode and it doesn't work.  The datasheet of the sensor specifies the current consumption for "Significant motion detector, gyro in suspend, accel in low power mode @50Hz", so I guess it is possible. Which parameters do I need to set for low power mode and significant motion interruption?
    Thanks!
    2 REPLIES 2
    elrhoul
    Long-established Member
    Hi, i'm facing a similar problem with any motion interrupt. I created a task and configured the BMI160 in normal mode but I don't know where is the problem to have an interrupt. Please someone can help me.
    void task_bmi160_normal_mode()
    //esp_sleep_enable_ext0_wakeup(GPIO_NUM_4, 1);
    //gpio_set_direction(GPIO_NUM_4, GPIO_MODE_INPUT);
    int_config.int_channel = BMI160_INT_CHANNEL_1;// Interrupt channel/pin 1
    int_config.int_type = BMI160_ACC_ANY_MOTION_INT;// Choosing Any motion interrupt
    int_config.int_pin_settg.output_mode = BMI160_ENABLE;// Choosing push-pull mode for interrupt pin
    int_config.int_pin_settg.output_type = BMI160_DISABLE;// Choosing active low output
    int_config.int_pin_settg.edge_ctrl = BMI160_ENABLE;// Choosing edge triggered output
    int_config.int_pin_settg.latch_dur = BMI160_LATCH_DUR_NONE;// non-latched output
    /* Select the Any-motion interrupt parameters */
    int_config.int_type_cfg.acc_any_motion_int.anymotion_en = BMI160_ENABLE;// 1- Enable the any-motion, 0- disable any-motion
    int_config.int_type_cfg.acc_any_motion_int.anymotion_x = BMI160_ENABLE;// Enabling x-axis for any motion interrupt
    int_config.int_type_cfg.acc_any_motion_int.anymotion_y = BMI160_ENABLE;// Enabling y-axis for any motion interrupt
    int_config.int_type_cfg.acc_any_motion_int.anymotion_z = BMI160_ENABLE;// Enabling z-axis for any motion interrupt
    int_config.int_type_cfg.acc_any_motion_int.anymotion_dur = 0;// any-motion duration
    int_config.int_type_cfg.acc_any_motion_int.anymotion_thr = 20;// (2-g range) -> (slope_thr) * 3.91 mg, (4-g range) -> (slope_thr) * 7.81 mg, (8-g range) ->(slope_thr) * 15.63 mg, (16-g range) -> (slope_thr) * 31.25 mg
    /* Set the Any-motion interrupt */
    bmi160_set_int_config(&int_config, &sensor_bmi160); /* sensor is an instance of the structure bmi160_dev */
    while (1)
    bmi160_get_sensor_data((BMI160_ACCEL_SEL | BMI160_GYRO_SEL | BMI160_TIME_SEL), &accel, &gyro, &imu->sensor_bmi160);
    #if 0
    float ax = convert_raw_acceleration(accel.x);//
    float ay = convert_raw_acceleration(accel.y);
    float az = convert_raw_acceleration(accel.z);
    float gx = convert_raw_gyro(gyro.x);
    float gy = convert_raw_gyro(gyro.y);
    float gz = convert_raw_gyro(gyro.z);
    #endif
    float ax = getAccelerationBMI160_x();//
    float ay = getAccelerationBMI160_x();
    float az = getAccelerationBMI160_x();
    float gx = getGyroBMI160_x();
    float gy = getGyroBMI160_y();
    float gz = getGyroBMI160_z();
    ESP_LOGI(TAG, "[ACCEL] X: %2f, Y: %2f, Z: %2f", ax, ay, az);
    ESP_LOGI(TAG, "[GYRO] X: %2f, Y: %2f, Z: %2f", gx, gy, gz);
    int_status_sel = BMI160_INT_STATUS_ALL;
    rslt = bmi160_get_int_status(int_status_sel, &interrupt, &sensor_bmi160);
    if (interrupt.bit.anym)
    printf("Step detector interrupt occured\n");
    //esp_light_sleep_start();
    /* Task delay */
    vTaskDelay(10 / portTICK_PERIOD_MS);
    vTaskDelete(NULL);
