    BMI160 Simultaneous Single and Double TAP interrupts
    FortyTwo
    I am observing the following situation:
    1) If I enable and map only  the SINGLE tap interrupt , that event fires and I can see its  bit in INT_STATUS.
    2) If I enable and map only the DOUBLE tap interrupt, that events fire successfully as well.
    3) But if I enable and map both interrupts, only the DOUBLE tap is detected and relevant bit updated in INT_STATUS. And I don't mean that double taps are shown only as such: ordinary single tap without an accompanying second one is not detected. I even tried to map these events to different output pins, but the result is the same.
    Can someone please confirm that this is indeed a limitation? I didn't find such info in the data sheet. Thanks!
    Vincent
    Re: BMI160 Simultaneous Single and Double TAP interrupts
    Yes,  what you found is indeed the expected output from BMI160.
