    BMI160 Spi read chip_id
    Lmuh
    I want to communicate spi with pigpio library, but I'm stuck on the simplest thing. I want to read BMI 160 chip id. The code I wrote is below. Before I run the program, I run pigpiod, there is no problem with my connections.
    import pigpio
    import time
    pi=pigpio.pi()
    h=pi.spi_open(0,50000,0)
    # chip id register adress=0x00
    # read register adress msb bit 1 0x80
    (xx,data)=pi.spi_xref(h,[0x00 | 0x80 ])
    print(data)
    # not print data=0xD1 ,print data =0xff
    Hello Lmuh,
    You can refer to the code logic of the sensor API, activate the SPI interface first, and then read the chip ID via SPI.
    * @brief This API is the entry point for sensor.It performs
    * the selection of I2C/SPI read mechanism according to the
    * selected interface and reads the chip-id of bmi160 sensor.
    int8_t bmi160_init(struct bmi160_dev *dev)
    int8_t rslt;
    uint8_t data;
    uint8_t try = 3;
    /* Null-pointer check */
    rslt = null_ptr_check(dev);
    /* Dummy read of 0x7F register to enable SPI Interface
    * if SPI is used */
    if ((rslt == BMI160_OK) && (dev->intf == BMI160_SPI_INTF))
    rslt = bmi160_get_regs(BMI160_SPI_COMM_TEST_ADDR, &data, 1, dev);
    if (rslt == BMI160_OK)
    /* Assign chip id as zero */
    dev->chip_id = 0;
    while ((try--) && (dev->chip_id != BMI160_CHIP_ID))
    /* Read chip_id */
    rslt = bmi160_get_regs(BMI160_CHIP_ID_ADDR, &dev->chip_id, 1, dev);
    if ((rslt == BMI160_OK) && (dev->chip_id == BMI160_CHIP_ID))
    dev->any_sig_sel = BMI160_BOTH_ANY_SIG_MOTION_DISABLED;
    /* Soft reset */
    rslt = bmi160_soft_reset(dev);
    else
    rslt = BMI160_E_DEV_NOT_FOUND;
    return rslt;
