08-31-2020 03:56 PM - edited 08-31-2020 08:16 PM
Hi Community,
I am trying to implement an ultra low power version of an out of bed detection. I do not want to use interrupts.
Is there a way to set the sampling rate lower than 0,78125 Hz, or is disabling and re-enabling the only solution? Sample rate of about 5sec would be great. Because I want to calculate the average of 30 sec and send it to the smartphone.
Kind Regards,
wela
08-31-2020 11:38 PM
The current lowest ODR supported by our acceleration sensor is 0.78Hz.
If you need even lower ODR, i will suggest you to set sensor to suspend mode, then wake up sensor manually by system timer, after getting some data then set to suspend mode again.
