I have two questions about the BMI160-acceleration sensor.
Im using the BMI160 sensor with the Arduino ide programme to get gyroscope and accelerometer data for a project. I have no problem to get the gyroscope data on the serial monitor with the following command :
BMI160.readGyro(gx, gy, gz);
I tried to get the accceleerometer data with the same command "BMI160.readAccel(gx,gy,gz)" or "BMI160.readAcc(gx,gy,gz)" but without any success. How do I get the data? What do I have to write into my programme?
My second question is about the stored Gyro- and Accelleration data. What is the unit, the data is stored and is shown on the serial monitor? How can I convert them into °/s (Gyro) and m/s^2 ? I could not find anything in the datasheet.
Kind regards
Sophie
ok, that was easy. Thank you!!
Can you help me with the converting?
Is it right to multiply the raw accel data with the LSB value(typ.) (from the datasheet, sensitivity) to get m/s^2 ?
Do I do the same calculation with the raw gyrodata and its LSB value(typ.)?
How do I know which range I am having in my programme, when I did not set any?
Kind regards
Sophie
Hallo,
I have the same problem . How I dan convert the raw data (get from function "getAcceleration(...)") to m/s^2?
