    BMI160 bias/drift given value in datasheet
    Soup
    where do I find the estimated/declared value of the bias in the datasheet from BOSCH ?
    Is there a value in the table on page 8/9 for accelerometer data and gyrodata?
    for accerlerometer data Zero-g-Offset?
    for gyroscope data Zero-Rate-Offset?
    Kind Regards
    Sophie
    FAE_CA1
    Thank you for your inquiry. BMI160 datasheet has specified typical accelerometer zero-g offset of +/-150mg soldered over life time and typical gyro zero-rate offset of +/-3dps.
    shellywang
    Occasional Contributor
    Hi Sophie, For accelerometer, the typical zero-g offset is +/-150mg soldered over life time. For gyroscope, the typical zero-rate offset is +/-3dps.You can find details from page 8 ~10 of the datasheet.
    The datasheet for the BMI160 seems to specify the zero-g offset for the 8g range. Is there any data/specification available for the 2g range?
    Thank you!
