    BMI160 converting data with resolution
    Soup
    Hello
    How do I convert the Rawdata of the Gyroscope and the accelerometer into °/s and m/s^2?
    Do I need to multiply the raw data with the typ. value of the sensitivity? (LSB/°/s)
    How do I know which range I am having in my programme, when I did not set any?
    Kind regards
    Sophie
    7 REPLIES 7
    shellywang
    Occasional Contributor
    Hi Sophie,
    -----> For Acc if the register data is 16-bits
          Sensitivity(in datasheet) = (2^15)/Range .
          Example:  Range = +/-8G, then sensitivity = (2^15)/8  * 9.8   (LSB/m/s^2)
          m/s^2 = Raw_data / sensitivity
          For Gyo , if the register data is 16-bits
          Example: Range = +/-2000dps, then sensitivity = (2^15)/2000  (LSB/°/s)
          °/s = Raw_data / sensitivity
     -------> No. Raw data (LSB) divided by the corresponding sensitivity
     -------> please check the sensor's datasheet register map,
            Address 0x41 for Acc range setting; 0x43 for Gyro range setting
    Nikosant03
    Long-established Member
    The registers according to the datasheet are 2bytes for each axis for accel and gyro. See DATA register 0x04 - 0x17 pg51 or register map pg48
    Hope this helps
    Nick
    @Nikosant03 Thank you for your answer! The other question is: Where I can find the Information  that for a 16-bit register I have to do (2^15)/range for the sensitivity. I did not find this in te datasheet.
